LIPO BATTERIES
LIPO BATTERIES
I wanted to know what will be the better battery setup for my ofna spec 1e with the mamba 2200
1 6s battery
Or
2 3s battery?
And when you use two packs does you c rating double or does it remain the same?
1 6s battery
Or
2 3s battery?
Are they wired up in series or parallel? If series, the voltage is doubled. If parallel, the current capacity is doubled.
Do you want speed or run time? Voltage = speed, current = run time.
Will the Mamba handle 6s?
I was looking for speed... How do you wire a battery parallel and series?
And I noticed that the 3s had more c than a 6 s.....AND WHAT BATTERY DO YOU GUYS THINK IS THE BEST FOR SPEED?
This page does a pretty good job explaining the wiring.
http://traxxas.com/support/Using-Dua...16-Scale-Model
So how much current do you really plan on pulling from the batteries?
As far as battery choice... that's a long discussion & been done several times. Do a little searching.
Ok thanks guys
