Old 12-09-2002, 08:50 AM   #1
Aluma's Avatar
Default what the better rally car?
Hpi rally
tc3 with rally conversion
TamiyaTB01 with long arm
Tamiya TL01 LA
Aluma is offline   Reply With Quote
Old 12-09-2002, 09:53 AM   #2
Trader Rating: 24 (100%+)
Hey Aluma,
might as well put my 2 cents in even though you're looking to buy my rally.....
1.tl01 LA forget about it... the tl01 was never meant to be a rally chassis. Tamiya makes the Baja Champ buggy using the TL01 main chassis if you want to go that way
2. TB01 with long arms......Good,I have one....but the longer arms are primarily for handling. The shocks remain the same so shock travel is still short.
3 TC3 with conversion....haven't tried it...but I imagine it's much like the TB
4. Purpose built rally car...lots of shock travel. if I weren't hard core Tamiya...thats what I'd use.
Evoracer is offline   Reply With Quote
Old 12-09-2002, 09:59 AM   #3
Well the HPI has to have it's protective sheil, so that makes the electronics run hotter.
TL01 and TB01 come as Ralleys in the box, so that will save you a few dollars.
However the TC3 and conversion may be the best handling car, but also the easiest to brake......
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 12-09-2002, 10:14 AM   #4
The HPI is actually better because of the protective shell. The battery, speed control and receiver should never get that hot anyway. The motor is NOT covered and thats where all the heat is.
Old 12-09-2002, 10:35 AM   #5
Here's my .02 cents. The Losi has a lot of good things going for it. Ball diffs, bearings, adjustable one way, lots of aftermarket parts, sealed driveline, aluminum shocks. Downsides though, only 190mm, Stock rally tires aren't worth a darn, has special size wheel hex.
Action-RC.com is offline   Reply With Quote
Old 12-09-2002, 10:56 AM   #6
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
my .02
Had or driven most all of the Rally Cars.
1. TC3, great handling, but dirt in the steering rack is a big problem.
2. HPI, prolly the best all around rally car, very durable, and no matter, the inner body is a great addition, some people vent them.
3. Ofna. just say no
4. Losi. Good car, hard to wrench on, but very durable.
5. Tamiya cars. TB series prolly a better choice
6. Yokomo. Hard to find, pretty good car.
7. Schumacher Great car on the small stuff, not good for the really rough, also has an inner body
I am sure other people can comment
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 12-09-2002, 12:23 PM   #7
Aluma's Avatar
yeah....the tc3 does look kinda flimsy
I know the tb is a tank and has limited arm travel.
and I know the hpi has those belts which tend to break...
but i need ground clearance so i guess the HPI is still gonna be the best choice.
Just wish i could find one with all the hopups on it already....
I didnt want to buy a stock one cuz then I'd have to spend a fortune on the slipper for the belt, the rrp top shaft, carbon top chassis, and the MIP's.
Old 12-09-2002, 01:39 PM   #8
TimPotter's Avatar
None of the guys around here run the Slipper. Personally I run a Rally weapon with the front clicker locked, my RW has been next to bulletproof, just dont like the saddle packs.
BTW, there are a coupl eof HPI's on ebay right now.. NIB for around 100
Old 12-09-2002, 03:20 PM   #9
newracer's Avatar
R/C Tech Charter Subscriber
I have the HPI and it works well. It is almost bullet proof. I have busted a few graphite rear shock towers but that was from launching it about 4 feet in the air for about 25 feet onto asphalt. I bought mine used and got a really good deal. Mine has aluminum bulkheads, hubs, steering blocks and steering arms, Ti turnbuckles, graphite shock towers, RRP top shaft, slipper, and MIP shiny CVD's. All I need is a heat sink motor mount.
newracer is offline   Reply With Quote
Old 12-09-2002, 06:17 PM   #10
Cole Trickle's Avatar
The most important thing to consider, are support. Check out your LHS. Get a car, which are good supported locally. If you need a spare part and cant get it fast, well, no driving....
HPI belts dont break. Well, unless you abuse them. That is, if you keep the throttle on, while the car cant move because it's driving into something.
The HPI Rally are solid as a tank. It drives good. It got ball bearings. And if you someday want to get into touring, the HPI Rally can do that as well, with a little conversion. I've seen one in a touring race - the guy won his class.
Good luck.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
losi rally weapon or hpi rs4 rally ? guss Rookie Zone 9 11-13-2010 08:19 PM
Wanted, HPI Rally car, or other rally car Casey R/C Items: Wanted to Buy 12 12-23-2008 09:36 PM
tc3 rally arms/rally kit Zac R R/C Items: Wanted to Buy 3 09-18-2005 06:46 AM
TC3 Rally (and rally in general as well) NOSaholic Electric Off-Road 19 10-13-2004 10:33 AM
RS4 Rally for trade for a different rally car rcdude48 R/C Items: For Sale/Trade 19 06-17-2003 01:35 PM
