Bullet connectors on motor Post ur pics >
Like Tree13Likes
Old 10-08-2019, 03:35 PM
fat500's Avatar
Trader Rating: 33 (100%+)
Default Bullet connectors on motor Post ur pics
who is using bullet connectors on their motors??? please post some pics.
Do you notice any performance issues? Do they cause the speedo to run/get hotter? What size are you using? Resistance issues? Thanks to all
fat500 is offline
Old 10-08-2019, 03:51 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 210 (100%+)
i have been using them for almost 2 years no performance difference, if any i cant tell from the driver stand. I usually run 2 classes 17.5 and 21.5 USGT and i can swap motor and tires in about a minute i wouldnt use them with mod motors
JerseyRC likes this.
Marcos.J is offline
Old 10-08-2019, 03:52 PM
Super Moderator
Marcos.J's Avatar
Slo_E4 and Brian10811 like this.
Marcos.J is offline
Old 10-10-2019, 04:58 AM
fat500's Avatar
Ended up with this I'll report back how it works see if I noticed any difference in my lap times ESC temp or motor temp
fat500 is offline
Old 10-10-2019, 05:46 AM
+1
JerseyRC is offline
Old 10-10-2019, 05:53 AM
Brian10811's Avatar
I knew you could not wait to post up on this thread.
Slo_E4 likes this.
Brian10811 is offline
Old 10-10-2019, 06:12 AM
Mine
JerseyRC is offline
Old 10-10-2019, 06:50 AM
Super Moderator
Marcos.J's Avatar
lol
Marcos.J is offline
Old 10-10-2019, 06:53 AM
dawgmeat's Avatar
Marcos.J likes this.
dawgmeat is online now
Old 10-10-2019, 07:02 AM
Lonestar's Avatar
No reason why you'd lose that much voltage if this is done properly and with quality plugs... the key is "done properly" I'd say - ie make sure your soldering skills are up to expectations
Lonestar is offline
Old 10-10-2019, 07:20 AM
The thing to do.. is test the resistance across the connector. Like RC Car Action used to do with battery connectors.
Nerobro is offline
Old 10-10-2019, 09:15 AM
Zerodefect's Avatar
Connectors have lower resistance than my meter leads connection point.
Don't sweat it. Keep them clean and tight.
Zerodefect is offline
Old 10-10-2019, 09:31 AM
That's where a bench meter, and a 4 lead setup comes in to play.
Nerobro is offline
Old 10-10-2019, 04:02 PM
gigaplex's Avatar
If you need to go to that much trouble to measure it, the resistance is low enough.
Lonestar, Nerobro and MC112b like this.
gigaplex is offline
Old 10-10-2019, 04:07 PM
JerseyRC is offline
