Schumacher Mi7
#301
I worked with Tony Newland of Klinik to get a thicker top deck made for the car. I felt like the super flex of the chassis made it unpredictable on medium/high grip asphalt. He made a carbon copy of the stock deck in 3mm...here is my quick "race report" on its changes.
Hey just wanted to give you a small report from racing this weekend. unfortunately the fast guys werent out this weekend but I feel like the thicker top deck really tamed the car down. Setup changes are more minute. half mil changes up front were big changes and now its more subtle which I think can be a good thing. Overall the car felt more consistent since it was less twitchy up front.
here's the results from yesterday.
https://jerseyrcracers.liverc.com/re...ult&id=2582928
#302
Super Moderator
#304
#307
Just got done building my MI7 and I have to say Schumacher did an incredible job on everythign from packaging, instructions and design. Cant say Ive had a car build go as smooth and relaxing as the MI7 in quite some time.
Its gonna be a bit before its virgin run but Im excited for it. I'll be running indoors on black carpet, about medium bite and was wondering what drivers springs choices have been. Its gonna be 17.5 rear motor setup to start with plans for the vertical plates. What are some good spring choices and places to get them?
Thanks.
Thanks.
#308
Super Moderator
Thanks.
Thanks.
#309
Im planning to run the carbon chassis for a bit while I learn the car. I may switch to an aluminum chassis after I get it settled.
I have the rear motor chassis copied and can cut my own so I can play with designs.
#310
Thanks.
Thanks.
If the carpet rests on a subfloor, the grip levels are much higher than if the carpet rests just on concrete.
In testing, I have found the kit springs to work well and body choice is important, and if the carpet is on top of concrete with no subfloor, track surface temp is lower, meaning you should use a body that creates higher down force body to generate heat/grip in the tires. Was at the track yesterday, concrete temp was 18.7 degrees Celcius, as was the carpet.
In the process of uploading some head cam video, will be posted there.
#311
Mi7
After struggling with the t4xray 2018..I switched to the mi7 mid motor. Aluminum chassis is must for black carpet, stock springs. Installing a front diff with 20k works great, eliminates breaking the front inner drive paddles. I ran 28/32 tires in front & 24 in back. Let a couple of the pro drivers try it ,they all said it was stuck like glue .... Love it, I'll never buy another x-ray after this.
#313
Ran the MI7 over the weekend with pleasing results. Having trouble with getting the droop down to 4mm/4.5mm due to shock length been to short. I have built the shocks with 10.5mm inner length. I,m using 10mm droop block and droop gauge with carbon strip under it. Could someone give me their over all length of shocks. Doing exactly what I seen on facebook page, bit lost on what I may be doing wrong.
#314
Super Moderator
#315
Anyone want to or have some good education on the ARS on this car?
Only running 17.5 on black crc carpet with the house tire being Sweeps ..... is there any benefit to adjusting or using the ARS on the car?
Would I want the outside rear tire to turn a few degrees to rotate faster? Would it hurt the wheelbase at all? I watched a youtube link MarcoJ posted in another thread and it talked Caster so thats why i ask that.
Also thinking of it ..... with the upper arms the way they are can you or would you want to set up a reactive caster on this car? Incase Im calling it wrong Im talkig about the rear ball stud higher then the front one only on the front of the car?
Its been a few years since I ran TC but this car really has me excited about it, just a few small things left to come in before I can actually run it. Just trying to educate myself on some of the new things the cars have to offer.
Thanks.
Thanks.
