Schumacher Mi7
#182
I upgraded my MI7 with a front diff . Running 20-k in front & 7-k in the back (21.5 FT TC ) . Big difference on a high traction twisty track on black CRC carpet . Couldn't make the hairpins before I added the diff. Also broke a couple of the plastic drive yokes , due to the binding between the front wheels using the spool. Yes, the diff is a piece of art. I'll never buy another x-ray after putting the Mi7 together.
#183
Tyler beat me back to rc tech, yea I was able to take the win in the 17.5 class. Running the mod motor and standard carbon chassis. I’m sure the aluminum would have helped, but I typically run asphalt. Car is def better on carpet than asphalt so far, but I have only had about 4 race days on it. But super solid so far!
#187
#188
It is pretty solid on asphalt as well, thats what i normally run out in arizona. I was lacking motor for Tyler and some of the fast locals. I bought the R1 for this race and was able to pull some people this weekend. I had all day fri to make some tweaks and practice. I needed to make it more reactive, the thing i have noticed with this car is there is a huuge setup window, consistent and easy to drive but need to have it more on edge.. ill post again when i run it back on asphalt.
#189
#190
i could use some help...it seems like the drive train is a little stiff...belts aren't tight...do they need a little time to break in ?
#191
You can also check to make sure your center pulley spins free and doesn’t bind up.
#192
Super easy to drive
Had a full test session with the Mi7 at the local track yesterday and I am very impressed with how well this car works. In my first session after an extended layoff from racing, I started by running 17.5 - the stock setup plus some stiffer springs and the car is very close. Rotates well - very balanced and reacts well to user feedback.
Yesterday, I installed the aluminum chassis and made the car even more balanced in my opinion. The track I have locally is high traction black carpet. Very tacky as the facility is 24/7 and has racers on the carpet daily.
I made a few adjustments from the kit set up and wow - it really woke this car up.
A super quick through the corners and so stable - I think the level of grip this car has while still being able to rotate is impressive- it’ll be great once I move back to racing modified.
The Mi7 is very tough As I had a couple incidents and the car held up excellent. No chassis tweak and no broken parts.
I am looking forward to racing this car and can’t wait to get some more time behind the wheel.
#193
Location: Everett WA in the Summer Mesa AZ in the Winter
So I see there is an Mi7 Pro. How does it differ from non pro?
#194
Where have you seen that? It's the same part number on Schumacher's site.
#195
