Like Tree630Likes
Schumacher Mi7
Old 11-21-2019, 10:05 AM
  #151
What is a good starting spur for 17.5 on a medium size black carpet track?
ChadoSan is offline
Old 11-21-2019, 11:07 AM
  #152
patorz31's Avatar
Im using a 100t
patorz31 is offline
Old 11-21-2019, 12:20 PM
  #153
I guess I should actually say what is a good final drive ratio to start with?
ChadoSan is offline
Old 11-21-2019, 01:49 PM
  #154
patorz31's Avatar
That depends on the motor you are using. Start with 4:1 and work your self up or down to get the laptimes you need. Some guys in my club run 4.21:1 while I use a Team Powers Actinium V3 with a super strong rotor and I run 3.8:1
patorz31 is offline
Old 11-21-2019, 09:44 PM
  #155
STLNLST's Avatar
Trader Rating: 32 (100%+)
Really curious to see this car on asphalt more. Due to winter approaching I'm sure everyone is all carpet.
STLNLST is offline
Old 11-22-2019, 04:03 AM
  #156
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
my friend is racing it locally and it looks really good
Marcos.J is offline
Old 11-22-2019, 05:14 AM
  #157
STLNLST's Avatar
what class is he running?
STLNLST is offline
Old 11-22-2019, 07:34 AM
  #158
Super Moderator
Marcos.J's Avatar
17.5
Marcos.J is offline
Old 11-22-2019, 11:52 AM
  #159
MaxRain's Avatar
Depends on how you have timing set on your motor, as power generated changes the torque curve when you adjust it.
Essentially you don't want to run out of RPM at the end of a straight, and gearing accordingly is necessary..
With the Mi7, the amount of window space for changing pinions is relatively small, as you can't move the motor as much as you could on an Xray for example.
This is because we can easily change the spur to any size if necessary, which is what I really like about this car. Nothing worse than having to take over 20 mins to change a broken spur, which I hated doing on an xray.
As for spur gear I am currently using 104T 64 pitch.
Watch the video here
MaxRain is offline
Old 11-22-2019, 12:36 PM
  #160
Super Moderator
Marcos.J's Avatar
Schumacher Mi7 testing
glad you moved that chair out of the way then your car wouldnt have flown off the track jk
Marcos.J is offline
Old 11-23-2019, 07:42 AM
  #161
MaxRain's Avatar
Lol, hahahaha, glad you noticed that...
For those who are interested, went head to head last night in TC stock. Ran the mid motor setup, against mid motor Amx car, Gizmo, VBC, T4's, and AE 7.2.
The first two rounds of qualifying, I ran a 21.5, then switched to 17.5 .
With the 21.5 I qualified 5th, but then switching to 17.5, I qualified 2nd.
Guys at the track were impressed, and I am back at the track tomorrow for more testing to see if I can gain a tenth or two.
If you have any questions, send away....
Q1 Schumacher Mi7 TC stock 21.5
MaxRain is offline
Old 11-23-2019, 08:10 AM
  #162
STLNLST's Avatar
on my Yokomo I also found that the space for shifting the motor was limited compared to running the car in rear motor form. However....changing the Spurs on the Medius kit is quicker than in rear motor form. Still love the features the MI7 has and I still have all my springs so staying with a traditional shock car would be better than switching to Awesomatix. Keep up the good work and have fun.
Robert K likes this.
STLNLST is offline
Old 12-01-2019, 02:23 AM
  #163
Since there are just five setup sheets on petitrc,can everyone share there set-ups. Not much info out there.
vktrgrgv is offline
Old 12-02-2019, 11:03 AM
  #164
ChadoSan is offline
Old 12-03-2019, 08:07 PM
  #165
ChadoSan is offline
