Serpent X20
#331
Those long screws, I am almost certain were first seen deployed on the 4x platform but never fully explained. I think I saw them on Viktor's car some time ago. I must imagine that in races when you can use very thin bodies, it must help when the body bends under high speeds.
Steve
Steve
So that was my first thought, as I mentioned above, since maybe the pressure on the rear wing might make it buckle in the rear, but then I saw the rear body post collars on Yugo’s car, and they look like they are well above the reach of those screws, so that’s where I Drew a blank.
#332
Well, I first saw them on Felix Law’s 4X on the front upper arms, where it was explained that it helps support the hood from caving in under the pressure of the air hitting these ultra lightweight bodies at speed up front.
#333
Car is going super sonic in a straight line and has soft suspension settings, it then turns into a hard left sweeper so the chassis and body lean to the outside which would be the right side. However the right suspension would then lean upward moving that screw in the rear upper arm up towards the body which is leaning downward. The goal would be to keep the light and flexible body off the carpet (digging in) and also off the rear tire, which can cause sudden unpredicted cornering. That's my best guess.
Steve
#334
It kind of makes me wonder if any of this stuff will lead to a running change. I know there were quite a few things on the 4X Evo that eventually made its way into the Pro kit. I would be most interested to see if the additional post that Yugo had installed in the mid-rear makes its way into production.
#335
He qualified 7th at ETS this weekend which was good considering the field https://www.myrcm.ch/myrcm/report/en/49404/245157
#336
#337
What was also interesting (if I understood correctly) is that he put some anti-dive into the front end?
#338
I think I figured out the screws in the upper arms.
They are for supports to float the body, BUT, he was running front upper arms in the rear......so he was probably just using a set that he had previously installed in the front.
Mystery solved.
Mystery solved.
#339
Interesting shock settings for Micro Thalheimer from the ETS race.
Drilled the shock pistons to 4 X 1.1mm and reduced the overall shock length to 55mm rear and 53mm front. Also drilled the shock cap 1.1mm to get 0 rebound.
Take note that's overall shock length which seems to be easier to get consistent settings over trying to set gap from shock body to spring perch.
#340
Is there REALLY a difference between the upper front/rear arms?
#342
Yes they are different:
#343
If you look at the video you can see that the length from the roll bar mount to the end of the arm is longer than on the stock rear arm. That and I am pretty sure I either read or heard them say that they have been running the front upper arms in the rear of the car, just never put that information together. Not sure why other than more material for the ball stud to thread in? But I'm just guessing on that.
#344
That's just that we can also see a lot of the ball stud thread... And the rear width was not excessive also... Honestly, I don't understand why they produce difference parts for front and rear, especially if drivers are using the front in the rear...
#345
Just to clear up and provide a little confirmation. A lot of us in the US are running front upper arms in the rear upper position. That is in everything from USGT thru Modified. There is no difference in them other than the length at the end to provide more support for the pivot ball threads when running a wider track width. As to why they just don't make them both the same, remember the US is the ONLY market on black carpet, the rest of the world runs a lot lower traction, and the narrower car rotates better when traction is low.
