Old 03-13-2006, 09:38 PM   #31
akuhon's Avatar
Default Home Built mini sedan.... just need the body
Hai all,
Glad I found this thread..
I've just made my own mini sedan based on my used TRF414M parts.
It's because I have too many spareparts of them and beside my local track is not fit properly for std 1/10 touring... (only M-chassis, IMO).
The only thing I need is the body shell since the threadwidth is still 190mm (I use same arms, etc). I think T1M is only 165 mm but I don;t know the yokomo.
Check this out.
Compare to M-chassis (M03)
http://i44.photobucket.com/albums/f9...-wheelbase.jpg
http://i44.photobucket.com/albums/f9...read-width.jpg
http://i44.photobucket.com/albums/f9...-long-slim.jpg
http://i44.photobucket.com/albums/f9...-set-ready.jpg
akuhon is offline   Reply With Quote
Old 03-13-2006, 09:48 PM   #32
SpeedyDad's Avatar
vadn1,
I really like the way my car handles now so I don't want to got to 2wd.
I thought the front one-way was to improve off-power steering. In my case, I am never off power so that is not a benefit to me.
As far as 70 or 72 tooth spurs, like I said before, I am at the smallest I can go. Any smaller and the belt rubs the motor because I can't get a larger pinion.
As far as the lower ratios, I haven't had a chance to look into these yet. Are these diff ratios or center pulley ratios?
SpeedyDad is offline   Reply With Quote
Old 03-13-2006, 09:51 PM   #33
SpeedyDad's Avatar
akuhon,
That is pretty cool. I have two M03s and one M03L. All Mini Coopers. I am a big Mini Cooper fan (I have a full size New Mini) and bought the T1M used hoping to do a Mini Cooper body on it but the big tires on the T1M won't fit in the Mini Cooper body shell.
Old 03-13-2006, 09:55 PM   #34
akuhon's Avatar
SpeedyDad,
yes it won't fit the M-03
The tires is std 1/10 toouring... change it to foam and truer upto 63-64
How about the body width ? does it fit properly.... ?
And to what mini you try to exchange the body ? The M03 or M03L ?
Old 03-13-2006, 10:20 PM   #35
SpeedyDad's Avatar
The T1M uses the Yokomo body which is 165mm.
I tried to use the M03 body. The wheelbase is almost the same as the T1M but the tires on the T1M are just too big and rubbed a lot inside the front bumper.
Old 03-13-2006, 10:35 PM   #36
SpeedyDad's Avatar
OK, here's an idea that I thought up. vadn1 had mentioned using the smaller cells like they use in 18th scale cars but, at first, I had pushed the idea aside because of run duration. I revisited this idea tonight as I was looking at my Mini-LST 6 cell packs. They are the same width as GP3300 cells when configged in a 4 cell pack. They are also shorter in length (I can move them forward or rearward for chassis balancing). Together, two of these packs weighs 5 grams less than one of my GP3700 4 cell packs. I could also lose the weight of the battery posts and strap by using battery strapping tape through the 4 cell holes.
So, my question is, if I upgraded the wires on these packs to thicker wire and ran 2 packs in parallel, would this be a practical way to run 6 cells at the weight of a 4 cell pack or would there be amperage issues? The Mini-LST packs are 1100mah, but through Maxamps, I can get IB1400 packs for $28.50. Team Orion just announced 1600 mini packs recently too.
I get more than enough run time on my GP3300 packs so dropping to a combined total of 2800mah should be fine
Thoughts?
Old 03-13-2006, 11:44 PM   #37
SpeedyDad,
I don't know if I mentioned this earlier, but you have heard of the Orion Lipo packs? Xray offers a battery mounting system where you can place a 6 cell stick pack across the chassis. Team Orions platinum Lipo batteries are the same size as a 6 cell battery pack, so With the higher output and the lighter weight of the lipo batteries you should be set.
vadn1 is offline   Reply With Quote
Old 03-14-2006, 07:22 AM   #38
SpeedyDad's Avatar
I had not seen that yet. I'll have to look to see if it will fit in the T1M chassis. I am starting to look in to Lipos too.
Old 03-14-2006, 06:56 PM   #39
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
Is anyone running foams on theres?
roadrashracing is offline   Reply With Quote
Old 03-14-2006, 07:05 PM   #40
akuhon's Avatar
I see there are a lot of mini sedan beside those mention on the 1st post.
Currently I know there are :
1. ABC hobby Genetic with 2 bodies : Nissan cube and Mitsubishi Colt CZT
2. Active Hobby Minifan with many bodies and the latest one is Toyota Yaris / Vitz.
They are all mini sedan and 4WD...
Also I notice this pictures (TM-ONE), but I don;t know where to find. I think it's made early 2000. Is it made by Kyosho ? Check the pics
While for my homebuilt TRF mini, the original design was from HPI RS4 mini and later I saw somewhere in Japanese web about TA04-SSS. It's a mini sedan based on Tamiya TA04 chassis... while mine based on TRF414, basically it's the same but mine alot easier since the bulkhead is alum. not plastic.
Old 03-14-2006, 07:31 PM   #41
When I get time to race, I always use foam. For practice its rubber.
Old 03-14-2006, 07:50 PM   #42
SpeedyDad's Avatar
Rubber tires for me
Old 03-15-2006, 01:51 PM   #43
gonzo416's Avatar
Trader Rating: 39 (98%+)
where i race (carpet) the guys were using nitro foams and gluing the sidewall on the fronts due to too much traction.they seemed dialed.
gonzo416 is offline   Reply With Quote
Old 03-15-2006, 02:08 PM   #44
Send a message via AIM to R/C Anonymous
foams here...it's dialed and not even close to traction rolling
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 03-15-2006, 04:46 PM   #45
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Is there companys that make bodies for these? Personal I'm not a stratus fan.
http://www.speedtechrc.com/store/ebp...?catmainid=412
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
sedan setup thread roadrashracing Electric On-Road 14 10-16-2007 02:39 PM
FS: NEW Xray T1M Mini-Sedan SteveM R/C Items: For Sale/Trade 0 06-22-2006 06:47 AM
TRF mini sedan project akuhon Indonesia Racing 14 04-03-2006 10:58 PM
Sedan Body Shell Characteristics Thread chachi Nitro On-Road 73 07-15-2005 11:39 PM
19 turn Sedan Thread Neil MARCCA Discussion 3 02-20-2005 05:41 AM
