Best chassis for bumpy concrete track? >
Like Tree6Likes
  • 1 Post By herrokero
  • 1 Post By mac853
  • 2 Post By massenb203
  • 2 Post By 1spunspur
Old 09-05-2019, 08:47 AM
Default Best chassis for bumpy concrete track?
Hi, I'm going to be focusing on-road and the track will be slippy concrete with some bumps.
What would be a suggestion for a good chassis that fits these sort of conditions well? I guess I'm thinking a chassis that flexes a little more than normal and provides more feedback over bumps and tracks irregularities?
TIA
flatovercrest is offline
Old 09-05-2019, 09:12 AM
From the top of my head, and assuming this is about TCs, probably the Serpent 4X which has a 2mm lower deck out of the box or the Mugen MTC1 with something like a 2.15mm lower deck with the option of an "ultra flex" top deck that is pretty unique. Most other conventional TCs are 2.25mm and have similar designs that should be roughly the same flex wise, although some also have the option of a thinner top deck (around 1.6 - 1.75mm) usually intended to be used with alu lower decks. I don't know if it's a good idea to be used with a normal carbon lower deck, but it would definitely be more flexy
flatovercrest likes this.
herrokero is offline
Old 09-05-2019, 09:20 AM
mac853's Avatar
Technically i have some suggestions, but practically is not very easy to make it.
As i thought BD7 2013, TRF417X and HB Cyclone TCXX are best choice for low traction and bumpy tracks but I don't believe is easy to find these discontinued cars.
mac853 is offline
Old 09-05-2019, 02:50 PM
massenb203's Avatar
I would say that any of the newer cars would be fine with a carbon fiber chassis and tune it to the track that you are running it on.
flatovercrest and aracefan like this.
massenb203 is offline
Old 09-05-2019, 02:58 PM
Thanks guys. @massenb203 I agree with your statement.
Old 09-05-2019, 03:41 PM
1spunspur's Avatar
Hi flatovercrest, I've all ways believed that a stiff chassis is better on a rough surface so that the suspension can handle the bumps. In other words soft springs and shock oil and high traction threaded tires that would eliminate the unpredictability of a soft chassis. I know many people will disagree with me but that's my belief. On a smooth surface, I don't think a soft or stiff chassis is as critical. Again, many will disagree.
flatovercrest and glennhl like this.
1spunspur is offline
Old 09-05-2019, 04:07 PM
I guess it's personal preference based on your experience.
Old 09-05-2019, 04:26 PM
1spunspur's Avatar
Yes, experience (aprox.30yrs) and driving habits.
Old 09-07-2019, 02:24 AM
mac853's Avatar
My tips is finding cars which could use long spring shocks, from my experience the better is using HPI blue, silver or pink springs and use super soft spring in rear in case very slippery(eg: tamiya red, yokomo black)
In case is extremely slippery as polished concrete tracks, use rear ball diff, remove roll bars, try between Speedmind radial or rally tires and Schumacher radial or rally tires.
mac853 is offline
Old 09-07-2019, 04:00 AM
mac853's Avatar
TIA
You need to tell me race rules:
Motor power limit
weight limit
Tires are open or handout
mac853 is offline
