fantom motor dyno
Old 03-07-2006, 05:16 PM
Default fantom motor dyno
I just purchased a fantom motor dyno. What should I look for in a power supply? I need to know how many amps it should be able to hold. I would also like to know where I could get a resonably priced power supply.
kmorast is offline
Old 03-07-2006, 05:30 PM
James's Avatar
I know a guy with one that uses some 6-cell battery packs in series so he gets consistant numbers (doesnt trust a transformer?).. I dunno.. i would have thought the battery packs would provide in-consistant figures.
James is offline
Old 03-07-2006, 05:48 PM
Rick Worth's Avatar
12 volt lawn mower or car battery.
Rick Worth is offline
Old 03-07-2006, 06:52 PM
dakrat's Avatar
you need at least 75 amp power supply
dakrat is offline
Old 03-07-2006, 07:31 PM
Trader Rating: 23 (100%+)
I would recommend just getting a dry cell battery their like $60 sealed and run the dyno well. You could also get a lawn mowe battery just get the 240 amp version. Those two both work well and are a lot cheaper than a power supply.
AxiomJacob is offline
Old 03-07-2006, 07:35 PM
Kropy's Avatar
Depends on what kind of motors that you plan on running on the dyno, If you plan on just using the dyno for stock & 19 turn motors a 30 amp power supply will do the job, If you plan on using it for mod motors your gonna need to use a 75 amp power supply.
Kropy is offline
Old 03-07-2006, 07:41 PM
Thanks for all the help; I went out and got a auto battery. I may look at getting a power supply later.
kmorast is offline
Old 03-07-2006, 07:44 PM
While a 30 amp power supply will be able to handle the current, it will cause the readings to be innaccurate. I would suggest using a 70+ amp power supply if you want to use one, or just use a car battery.
rcguy2477 is offline
Old 03-08-2006, 07:53 AM
just mount a trickle charger on the side of the battery and your set till the battery dies. My whole setup was $30 and a powersupply was around 250
Old 03-08-2006, 12:06 PM
I use a lead-acid battery...
D_o_S is offline
