3RACING SAKURA ADVANCE 20M >
Like Tree147Likes
Old 06-25-2020, 02:48 PM
  #241
Originally Posted by Nortran11 View Post
Hey all, I have my 20M on the way. Ordered it along with the new 3Racing Aluminum chassis plate. So excited to get this car, I previously drove a Sport Xi Nu that I upgraded to Ultimate and was super impressed with the car.
Question......I noticed from the manual that the car comes with aluminum rear bearing carriers. I've been looking on the parts list for the car and can't find a plastic option, and the plastic part on the 2k18 doesn't list the 20M on the compatible list. I'd really prefer a plastic rear bearing carrier over the aluminum. What are my options?
Post #126 shows XRAY rear hubs. I am also interested on that part number or from which model?
jo_er86 is offline
Old 06-25-2020, 02:53 PM
  #242
Originally Posted by WillS View Post
I love the aluminum rear hubs but letís try something a little different for what Xray says gives more rear traction.
Also got my parts order in and the aluminum bones will help out the stock car greatly
Help a fellow out with the part number on that rear hub? I googled the T4 but it didnít look like that 🤔
jo_er86 is offline
Old 06-25-2020, 02:58 PM
  #243
theproffesor's Avatar
Trader Rating: 63 (100%+)
Itís most likely a part off of an earlier model Sakura. I would also suggest getting the front arms off an earlier model. The arms on the 20m are the same from the 2k18 and are super brittle.
theproffesor is offline
Old 07-02-2020, 07:34 PM
  #244
Nortran11's Avatar
Got my car this afternoon. Digging in for a build night!
Nortran11 is offline
Old 07-02-2020, 10:15 PM
  #245
alana07's Avatar
Trader Rating: 52 (100%+)
Seems like the Advance S6/4 kit has been released in HK, shops in Mongkok has it in stock yesterday.
jo_er86 likes this.
alana07 is offline
Old 07-03-2020, 10:03 PM
  #246
Nortran11's Avatar
Guys,
I am building the 20M and seem to be having an issue.....curious if anyone else ran into this. On the front steering knuckle, the SSK driveshaft doesn't seem to go all the way in and as a result, the pin will not go through the axle. I've reseated the bearings, I've tried numerous ways to fit it in....just won't go.
Anyone had this issue and how did you solve it? Also....the knuckle looks different from what is pictured. The knuckle has a long arm with three holes instead of two.
Any help would be greatly appreciated.
Old 07-04-2020, 06:33 AM
  #247
Guys,
Make sure you've got the narrow 5x10x3 bearing on the inside of the knuckle.
Kevin Marcy is offline
Old 07-04-2020, 07:51 AM
  #248
Yep... I had the same issue... after a long search (and RTFM )...I found out also that different bearrings are to be used.....
radje748 is offline
Old 07-04-2020, 03:05 PM
  #249
Nortran11's Avatar
Yup, I'm a dolt! I saw after a long search that there were in fact narrow bearings.....DOH!
Thanks!
Old 07-05-2020, 06:15 AM
  #250
gwc
Just bought the M20 on ebay for $279.00 shipped and the Alu. chassis and spare arms SAK-U101, SAK-U102 waiting to buy the Belt Tension Post For 3racing Sakura Zero SAK-58/BL to see if I have the loose front belt issue before I buy one 👀
gwc is offline
Old 07-05-2020, 08:55 PM
  #251
So I noticed that the plastic bearing holder for the spool gave my belt a lot of slack. So I bought the belt tensioner and might as well two pairs of aluminum bering holders for front and rear. Turns out the aluminum bearing holders removes excess slack and Iíve got a belt tensioner I donít ned anymore.
jo_er86 is offline
Old 07-14-2020, 11:32 AM
  #252
gwc
Thumbs up
Thanks for the info on the Alum bearing housing.
gwc is offline
Old 07-21-2020, 07:05 PM
  #253
gwc
SAK-A562 front belt tension pully
This should have been included in the kit!
gwc is offline
Old 07-21-2020, 07:20 PM
  #254
Thistle's Avatar
For those who have found the arms to be brittle, has anyone tried the old-timer trick of boiling the plastic to soften it a little and add some flex?
Thistle is offline
Old 07-22-2020, 03:49 AM
  #255
gwc
Originally Posted by radje748 View Post
ah ok perfect....it is this one:
SAK-A555 PULLEY For Advance 20M
SAK-A562 is the one for the front belt!
gwc is offline
