Tamiya TRF420 Thread
#436
Beautiful presentation Kentech
#437
Tamiya TRF420X vs TA07MSX
Hope you guys enjoy this one. 😊
#438
Kentech:
Does the curved motor mount front work well?
Is that the fan mount bar near the motor mount or something different?
Is the servo mount the lower height one seen in the TA07RR?
Last edited by F1jet_; 05-08-2022 at 10:04 PM. Reason: clarify could not post reply with picture
#439
Used the TFR420 for VTA on and off for a year and did not break anything. Only needed new body mounts and foam bumper when I swapped bodies.
#440
Does 420 bulkhead fit to 420x chassis plate? Then I can buy 420x motor mount and chassis plate, and combine with my 420 and TA08. What do you guys think?
#441
Nice video, clear, great music choice, no background distractions , nice animations. Very nice
#443
Do you know if TRF419 37T Aluminum Gear Differential Case and Tamiya 37t Aluminium differential pulley will fit TRF420X?
thanks.
thanks.
#444
- Do you mean the front part of the two-piece motor mount? I see no issues with this, but still have not run the car.
- Yes, that's the new fan mount. It is mentioned in the presentation below the photo of it.
- Not sure what you mean by lower height. I don't have any experience with the TA07RR. The 420X servo mount is a new part for the 420X, although very similar and interchangeable with the 420 version.
No you need to use the 420 diff/spool on the 420 and 420X.
