Spring Rates for F1 springs >
Like Tree2Likes
  • 2 Post By robk
Old 08-22-2019, 08:04 PM
Default Spring Rates for F1 springs
Is there as chart showing the spring rates for F1 springs : for the Front and sides?
Compairing Tamiya,XRay, Roche,CRC, Associated?
BullFrog is offline
Old 08-23-2019, 11:33 AM
MrUnlimited's Avatar
Tried their websites or try on Facebook. There are several F1 communities like this one: https://www.facebook.com/rcformula1/
MrUnlimited is offline
Old 08-23-2019, 12:53 PM
The degree of tolerance in manufacturing makes those type of charts very misleading. Better to measure the ones you have with a spring tester. Will alert you to springs that are supposed to be "matched" and aren't as well. You'd be surprised how "off" our supposedly matched parts really are.
Carnage9270 is offline
Old 08-26-2019, 08:23 AM
robk's Avatar
Trader Rating: 22 (100%+)
Pull 2 mm Allen driver out of toolbox.
put 2 springs you want to compare on shaft of wrench
compress springs.
the one that compresses more is lighter
not the most scientific method but it will give relative comparisons of springs. If you go slow, you can also see how progressive a spring is too.
Rick Vessell and dawgmeat like this.
robk is offline
Old 08-27-2019, 04:37 PM
I'm lazy- got my old spring tester back to test springs.
BullFrog is offline
