Old 03-08-2006, 06:57 PM   #31
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to HotrodHopkins
somethin like this???
SHAUN HOPKINS a.k.a NoRod Hopkins
-1990 Chevrolet K1500 Silverado TBI350 "Heavy Half". 1971 Chevrolet Nova
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 03-09-2006, 02:18 PM   #32
XrayFK's Avatar
Uh, what is going on there? lol I think you have a few too many connections
XrayFK is offline   Reply With Quote
Old 03-09-2006, 02:22 PM   #33
maybe, just and idea, i know it looks confusing, basically just posts at each end of the cell, and wires connecting to each one.
Old 03-09-2006, 11:37 PM   #34
Nickmind's Avatar
Send a message via AIM to Nickmind
Originally Posted by XingXing
buddy, spend $100 on a teamwave! its the best investment i ever done.
why waste $70 spending your money on components just to build a dinosaur that everyone is going to laugh at you and snicker behind your back
YOU SHOULD BUY TEAMWAVE STOCK. You are talking about that dam tray every thread i see.
Nickmind - 2 x savages, hyper 7, Revo 2.5, TC4, T4, 3 x 18T, CRT x1, Tmaxx, 8ight & 8ight-T 2.0 - all ran from a 3PK and spektrum.
Nickmind is offline   Reply With Quote
Old 03-30-2006, 10:12 PM   #35
aN4rK1's Avatar
sorry to bring this back up again, but i was just wondering, If i were to want a discharge cutoff of say .7 volts on my tray, what diodes would I buy?
aN4rK1 is offline   Reply With Quote
Old 03-30-2006, 10:28 PM   #36
on everypost? hardly. if someone ask what is the best equillizer then i will say teamwave. simple but otherwise i dont bring it up.
in anycase, if you have ever tried it them you too would recommend it. i am sure of it. i didnt buy one myself untill i saw it in action and my friend let me use his. he got angry coz i wouldnt use my smart tray anymore and kept on using his teamwave. i ordered one and got 1 week later. never looked back.
when i set it to the lowest setting, i can take out about 700mah more juice than a conventional equilizer, coz of its ability to lower the discharge amps (all the way down to 0.1amps) as it reaches its cut off point.
XingXing is offline   Reply With Quote
Old 03-31-2006, 08:37 AM   #37
XrayFK's Avatar
Almost all silicon diodes have a forward voltage drop of 0.7v.
Old 03-31-2006, 10:39 AM   #38
aN4rK1's Avatar
so any silicon diode will do? Do you think you can recomend me specific ones? And I would mount them as you mentioned earlier? The positive end of the diode to the negative of the cell? Btw, that would make my tray into a polarized tray correct?
Old 04-02-2006, 01:35 PM   #39
XrayFK's Avatar
Yes, it will be polarized. Get one that is at least 3A.
Old 04-02-2006, 03:17 PM   #40
Would it be easy to raise the discharge rate to, say, 5 or 6A? Is it simply a case of increasing the load? or would I need a diode rated to a higher current?
ralph_c is offline   Reply With Quote
Old 04-02-2006, 04:13 PM   #41
PlainOleDave's Avatar
Trader Rating: 14 (100%+)
Think aboput wutchu already know, If U pull 5 to 6 amps thru a 3 amp diode....
I would like to know if U kin use zenier diodes ( say rated at .9v)?
PlainOleDave is offline   Reply With Quote
Old 04-02-2006, 04:51 PM   #42
XrayFK's Avatar
Current = Volt/Resistance so the lower the resistance the higher the current. Then you also need a higher wattage resistor because it needs to be able to handle the increased power.
Old 04-03-2006, 09:49 AM   #43
So if I used a 5W 0.33ohm resistor what sort of discharge rate could I expect? could anyone suggest a diode that would work? I looked but wasn't sure what factors about the diode i needed (P600J ok?).
Ralph
Old 04-03-2006, 11:02 AM   #44
XrayFK's Avatar
Ralph
Discharge current would be around 3.5A and the cells would equalize around 2.1A. A diode that can handle the current would work.
WTB Equalizing Tray Shawner85 R/C Items: Wanted to Buy 2 04-10-2007 12:38 PM
Integy Equalizing Tray RED-LINE M03 R/C Items: For Sale/Trade 2 04-28-2006 09:25 AM
Equalizing tray Brandon Melton R/C Items: Wanted to Buy 2 03-19-2004 09:08 PM
Equalizing/Disscharge Tray Evo_Uk R/C Items: Wanted to Buy 4 02-07-2004 05:57 AM
Discharge Tray or Equalizing Tray???? jcr Electric On-Road 0 05-17-2002 06:00 PM
