Old 03-06-2006, 10:36 PM   #1
blackdog's Avatar
Default Gremlins in my FT TC4 need help
Hi
If anyone can help me out my new shoe's Ft TC4 has the IIC setup on it and
and the car rips through every corner but its way twitchy , Ive turned down my steering but still a ton of steering . anyone have a second opinion or set up (Recent one) like the Snowbirds race setup from 2006 ???
I'm thinking playing with the springs heavier in front might take a bit out the front but being a new ride I have to learn how to drive again and figure this rocket out and get it dialed so I can get back to top of the B'S and into the A's again .
Orlando if you see this the car Rocks man , very sweet ride (thanks again for the sale )
MAtt Roosevelt AKA Blackdog
blackdog is offline   Reply With Quote
Old 03-07-2006, 01:21 AM   #2
duckbutter's Avatar
Send a message via Yahoo to duckbutter
I just got my FT TC4 and I used set up number one. I seem to need more steering with this set up it mite be better for you. The car is great but Im going to get the xray T2.
duckbutter is offline   Reply With Quote
Old 03-07-2006, 02:21 AM   #3
bender's Avatar
Stick your car in direct sunlight, they hate that apparently
Sorry, couldn't resist.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 03-07-2006, 04:32 AM   #4
Frank N. Furter's Avatar
Apart from going to stiffer springs, you could try fitting an anti-roll bar and/or 4 degree blocks on the front.
Frank N. Furter is offline   Reply With Quote
Old 03-07-2006, 05:15 AM   #5
Theres a couple of things you can do, try putting some kickup on the front suspension. On the TC4 you want about 2 degrees,running it on 0 will make the car quite aggressive. Also you can increase the castor to 4 degrees.
Also take a look at the roll centre spacers, try lowering it.
Schumacher
Team Sorex
EA Motorsports
Speed Passion
East Coast Bodies
John Pape is offline   Reply With Quote
Old 03-07-2006, 08:39 AM   #6
AM03GT's Avatar
heavier front spring is a good way to start...
increase front damping...
add a front roll-bar...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 03-07-2006, 10:59 AM   #7
blackdog's Avatar
Thanks alot everyone for the tips & tricks
Keep theme coming , I'll get the car fixed for sure with everyone's contirbution's
Matt
Old 03-07-2006, 02:04 PM   #8
CristianTabush's Avatar
Best solution for removing twitchiness out of the front end I have found is to go to heavier oil in the front as well as removing front droop (picking the arms up more/ turning the screw clockwise to clear it up). This will make the front end react slower and remove that twitchiness feel. Stiffening the front end (stiffer springs, heavier roll bar, higher roll center) would not really diminish the twitchiness as much, for it would make the car have more exit steering and might make it bouncy, if the damping is not increased. Twitchiness (oversensitivity in the steering) Is usually caused by underdamping or too much suspension stroke in the front end.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 03-07-2006, 02:56 PM   #9
Veteq's Avatar
I just ran my new car at a club race in mod and it handled great. The setup i used was
front
Yellow springs
70 wt oil
number 3 piston
standard block with 1 shim front and rear
droop 4 mm
inner hole in the arm
second hole from the inner one on shock tower
no shim for the steering rack
Rear
Blue springs
40 wt
number 2 piston
2.5 degree toe in
Droop 2 mm
outer hole in the arm
second hole from the top on the shock tower
this setup was for Mod foam. I was also using Speedmind tires and parma alfa Body
Team Associated - Reedy Motors - Team Much More
Slapmaster Tools - Apollo Hobbies - Hi Performance Distribution
Overgeared B.O.D - [email protected]
www.AEforums.co.uk
Veteq is offline   Reply With Quote
Old 03-08-2006, 09:16 AM   #10
blackdog's Avatar
Default Hay
Your one funny guy there !!!
Arrghhhhh.......Stupid electical gremlins! intercede007 Rookie Zone 2 05-26-2004 11:43 PM
