Recess counter sunk screw holes in carbon fiber chassis >
Like Tree2Likes
  • 1 Post By Slo_E4
  • 1 Post By DesertRat
Old 08-08-2019, 02:48 PM
Fran's Avatar
Trader Rating: 198 (100%+)
Default Recess counter sunk screw holes in carbon fiber chassis
i picked up a couple of Associated 12R 5.2 knockoff main chassis and rear pod carbon fiber pieces a few years ago from someone on here. I just pulled them out and found out that the recessed countersunk holes arenít deep enough. The result are the screws arenít flush with the surface of the chassis when fully seated. Shat are my options? Is there a bit I can purchase to deepen the recess (1/16Ē!or less) I know I have to have a mask on and keep the dust to a minimum.
Fran is offline
Old 08-08-2019, 03:12 PM
AngryRog's Avatar
Trader Rating: 20 (100%+)
You will need to know the head angle of the intended hardware. And, use a drill press.
https://www.mcmaster.com/countersinks
AngryRog is offline
Old 08-08-2019, 03:18 PM
Racermac73's Avatar
Atlas tools, double ended 2 flute 90į 1/4 countersink carbide bit. About 20 dollars
Racermac73 is offline
Old 08-08-2019, 07:19 PM
Fran's Avatar
Perfect, thanks AngryRog and Racermac73, great info. Just what I was looking for.
Fran is offline
Old 08-10-2019, 09:13 AM
Trader Rating: 14 (100%+)
Or you could grind down the head of the screws. This works as long as you have a deep enough hex hole.
glennhl is offline
Old 08-10-2019, 10:35 AM
the rc guy's Avatar
Use a drill press with a depth limit on the head travel down. also use a vacuum with hepa filter next to press bead in the direction of rotation or chips travel.the more flutes the better counter sunk hole .less chance of tears.https://drillsandcutters.com/1-4-90-...afcde55def9557
the rc guy is offline
Old 08-10-2019, 06:44 PM
1/8 IC Fan's Avatar
Trader Rating: 96 (100%+)
doing this will remove any hardening, and make the screw weaker not to mention losing the depth in which the Hex Driver can engage is not a good thing.
Just get a correct countersink, Dragonplate may be able to advise you as to which bit. I use Ti/Ni coated CS bits.
1/8 IC Fan is offline
Old 08-10-2019, 07:34 PM
Racermac73's Avatar
Different screws might be easier, titanium tends to have a thinner head than steel. Steel screws vary from company to company also so a different steel might be ok
Old 08-10-2019, 11:30 PM
Use steel screws, not titanium, and just go slow on the grind so you don't overheat the head. Drill and tap a 3mm hole/thread into a piece of aluminum. You can then hold onto the aluminum while you grind and the aluminum will help carry away the heat you generate by grinding the head. And as I stated before, make sure you have a deep enough hex hole. I would grind some steel screws down before buying countersink tooling to deepen the countersink holes and risk breathing in some really nasty stuff.
glennhl is offline
Old 08-12-2019, 04:20 AM
Super Moderator
Slo_E4's Avatar
Trader Rating: 61 (100%+)
Drill presses, grinding heads on screws.... SMDH
Marcos.J likes this.
Slo_E4 is offline
Old 08-13-2019, 03:50 PM
Machining holes in carbon graphite, a carcinogen ...SMDH
glennhl is offline
Old 08-13-2019, 04:01 PM
DesertRat's Avatar
Known to the state of Cancer to cause California.
glennhl likes this.
DesertRat is offline
Old 08-13-2019, 04:13 PM
Actually thinking about it, I wouldn't machine on the graphite and I wouldn't grind down screw heads. I just throw away the plates and buy new ones. But that's because I'm lazy and extra cautious.
glennhl is offline
