Like Tree2Likes
  • 2 Post By SouthFloridaApp
Tires?
Old 07-29-2019, 09:27 AM
Default Tires?
What tires and foams do you guys think I should get? I am running on a large prepped indoor asphalt track. I will be using a tc3 if that makes a differance.
Dave0109 is offline
Old 07-29-2019, 04:49 PM
The best answer is to ask at the track that you will be running at. Try to ask the better racers...……...
eR1c and 1/8 IC Fan like this.
SouthFloridaApp is offline
Old 07-29-2019, 04:55 PM
eR1c's Avatar
Agree w what south Florida said,
different tracks will use different compounds on the track.
eR1c is offline
Old 07-29-2019, 08:19 PM
I second the ask your locals however ive tested allot but not everything. Ive never had a problem with sorex but I have allot of temp ranges and they seem to have the most graduations for temp.
however I have recently got my car setup for allot more traction and found the USGT tires are pretty darn good and they can be sauced in very well. I use mighty gripper and its a huge routine depending on temp but once you figure it out I can sauce a usgt tire down to a 28 or up to a 36 very well. Its probably not worth the time because the sauce is pricey but it does work. But i focus on getting the tires right first and then i dont really have to play with the setup much. Its just a preference.
Bry195 is offline
