A decent cheap shaft drive car touring car. Where did they all go?
#31
I want a mid-engine racer car at honda civic price or else I cry!
#32
A belt and pulley drive system with proper tooth profile will provide practically zero backlash. Belt can also smoothly stretch out according to how much torque is applied to the pulley. These characteristics seem to allow for the best traction control at the highest 1/10 Touring car racing level. A gear drive system is the opposite. It will always have some small amount of play or backlash. Gear teeth are designed to be strong and rigid, and can't be stretched the way a belt can. I don't race RC cars though, but these are the fundamental engineering differences. Maybe a pro racer can chime in and share actual driving experience between the two.
#33
#34
Lets run an experiment? What would it take to get a TT02s to "advanced touring car" status. Lets assume you're ok with using shims on the shocks. You still lose out on droop adjustment.. though there are aftermarket plates for droop.
- Droop adjustment plate - (I've seen them, but can't find one right now..)
- diff locking block (or JB weld lock..) ($13 for the tamiya part, $2 for glueing it.)
- Fluid filled diff ($32 for the tamiya part)
- CVD's for the front ($32 for tamiya parts, $10 for yeah racing)
- Spur adapter ($13 for tamiya parts, $9 for a proper spur, $5 for a proper pinion)
- heavy duty servo saver ($13-30)
- aluminum motor mount.
The following would be nice...
- hard tub ($8)
- threaded shocks ($22, for yeah racing)
- aluminum drive shaft ($13 for yeah racing, this gets rid of "spring" in the driveline)
- upper deck ($30)
#35
I don't think stretch, or backlash has any bearing on our conversation. But... torque might. I think that's the most believable story here. And why the "top end" tamiya uses a bevel drive on the motor instead of putting the motor parallel to the drive shaft.
WTCC's car is awesome, it is however, not cheap, not simple, not easy. It's a great way to strap the best bits you can to a ruleset that states you must use a TT02 tub. I love his projects.
#36
The backlash on a belt drive car should come mostly from the gear mesh between pinion and spur. With correct teeth profile design, there should be practically zero backlash coming from the timing belts and pulleys.
Have you ever tried shimming gears to the point where they have zero backlash? They would no longer be free moving at that point and efficiency would suffer by a significant amount. Not to mention the faster wear and tear from such a tighter gear mesh. Belt drive can maintain zero backlash, and is still almost as efficient as gear drive.
#37
Ok this discussion is totally sterile. There are shaft-driven chassis, some cheap, some expensive. The offer is already far over the demand, so there is no new chassis.
Go for a TT02-RR:
Go for a TT02-RR:
- Droop adjustment plate - Use shocks spacers
- diff locking block - Ride Putty75 is the way
- Fluid filled diff - INCLUDED
- Spur adapter (INCLUDED)
- heavy duty servo saver (INCLUDED)
- aluminum motor mount (INCLUDED)
- hard tub (why?)
- threaded shocks (again why?)
- aluminum drive shaft (INCLUDED)
- upper deck (why why why?)
#38
I'm .... careful.. on accessory purchases. :-)
- hard tub ($8)
- upper deck ($30)
This is why I’ve become a fan of used. I had always meant to try my TC4 for USGT. Just as a curiosity, no matter what it ran it would not have changed my finishing position
I still don’t know what droop does.
#39
I don't to be condescendant, but you really should study what is droop and what it does to the car... It can really change your finishing position!
#40
I stayed with simplified changes. Pinion/spur combination, shock/diff fluid. Then focus on consistency. I made the early mistake of being focused on speed in straight, but with our layout braking and acceleration were far more important.
For someone just stepping into racing. It’s an info overload, droop, tweak, camber, toe, ride height, FDR,.... Then there’s the opinions on bodies, and there different effects. And haven’t even turned a lap. Then there’s the whole new world of limited lane space( 8 feet seems wide till there’s 5+cars). For those of us that didn’t start on the racing side of hobby, just running in the limited space of a track alone is a big change.
I don’t dismiss the tuning part. Just don’t see it as the first thing to focus on for new people.
Didn’t mean to go off topic
#41
Howdy everybody,
There's a thread about recommending a dude a car. He's gonna be on unprepared surfaces, which really means "shaft drive". A couple times the TB05 were brought up. And the TT02. If the TC4 were still a production car, I'd be pushing that. But... alas, it's not.
Well the TT series cars, while neat and all, are really $30 of plastic $30 of motor and ESC, and a $30 body, with a $400 nice car fake it kit. So lets not talk about the TT02. The TB05, is a $300 car in the US. And while I don't think that's exorbitant, we have $100 belted touring cars. And $160 1/14 scale 4wd buggies. We should have a $100-200 nice shafty touring car.
So.. am I blind? or do we really not have a cheap, nice shaft drive touring car? Has the TC4's demise really meant that we're at the end?
Before I go, this is what I'd like to see:
- Adjustable upper links. (camber)
- Adjustable steering links. (toe)
- Standard spur gears. (Gearing for VTA through mod..)
- Gear diffs.
- Long suspension arms.
- Steel pivot pins.
- Adjustable rear toe, sweep, pro and anti dive.
- Flat battery mount, for modern lipos.
- multiple upper link locations for roll center adjustment.
- Standard suspension mounts for front sweep, pro and anti dive.
- parts commonality with other popular cars.
- flat chassis, for cheap aluminum, FRP, or carbon swaps.
https://www.amainhobbies.com/yokomo-...tc-sd9/p267795
https://www.redrc.net/2019/06/bjorn-...ng-series-rd5/
For those that have a TC4 and want to update the chassis with a modern design, this kit is also available.
https://kfrusa.com/products/kaizen-tc4-conversion-kit
#42
well, belts have one more interface than gears do. "each interface" has that hit. Belts have two pulleys for each end. Each belt to pulley interface has the torque hit. While a shaft only has the spur, and bevels. The belt has The spur, and four pulleys. Even single belt setups have the tension wheel that will add belt bending friction.
I'm so accustomed to low rpm and low power cars, I never considered that.
#44
These are still around. Its a budget version of the MR4-TC SD from early 2000's. I have heard it works really well.
#45
