Like Tree735Likes
XRAY T4'20 SPEC
Old 12-04-2020, 12:30 AM
  #1006
Originally Posted by bd007 View Post
are there shock towers to run the car with SLP shocks? Or the 2017 or older T4 towers fit?
you need the 20 version SLP towers
If you just use the lower holes in the arms I believe this doesn’t have the same effect and handling characteristics change.
Part numbers
301962
302962
BKUK is offline
Old 12-13-2020, 07:42 PM
  #1007
What’s the downstop settings for crc black carpet running 21.5 at apex? Thanks in advance
Disneytrks76 is offline
Old 12-14-2020, 05:30 AM
  #1008
Start with 1.25-1.5 for front and 1.75-2.0 for rear. this is over ride height.
freebird is offline
Old 12-14-2020, 05:44 AM
  #1009
Dan
Dan's Avatar
Trader Rating: 68 (100%+)
Can anyone comment on what springs rates front/rear that people have found out to work pretty good for VTA on black carpet?
Dan is offline
Old 12-14-2020, 06:14 AM
  #1010
NEED-MORE-SPEED's Avatar
I'm not a VTA guy. However I do assist a local driver that runs the T421 in VTA and ran the T420 for a season. We've found the 2.5/2.8 progressive hard springs work well on the front and 2.6 linear on the rear when the tires are fairly new (say 0 - 15 runs). Once the tires start to balloon and go soft, going to a 2.6 linear on the front and 2.5 linear on the rear helps keep the car flat and consistent.
If your budget allows a fresh set of tires in your program, front progressive hard and 2.6 rear is optimal.
Hope this helps
Dan likes this.
NEED-MORE-SPEED is offline
Old 12-15-2020, 04:08 AM
  #1011
KE4PJO's Avatar
It's ok to ask while at the track. I'll think you'll find it varies some from one person to the next. I tend to run higher droop settings than most, could be my problem (haha), but it gives me a more direct feel. I think a good starting point is in the 5.6-5.8 front and 4.6-4.8 in the rear.
gwc likes this.
KE4PJO is offline
