XRAY T4'20 SPEC
#991
Andrew,
Would you be willing to share a set up please?
I am running VTA and USGT on med traction black carpet
Thanks and God Bless
#993
Suspended
#995
car pushed when I first got it together. So I stood shocks up and that helped. Now, it’s stability in the direction change in s-curves or chicanes (can loose the rear easily in the low speed stuff if I’m to aggressive with the wheel)and forward bite out of the corners I lack.
#996
I used the setup out of the box. Have stood front shocks up one hole.
2.5-2.8 front springs
2.6 or 2.7 rear springs
3 degree rear toe
2 degree camber all round
carbon chassis 2mm top deck solid bushing.
3-5K diff oil.
1mm bumpsteer
0.5mm Ackerman
5.2f 4.2r droop
-0.75 hexes all round
Twister bodyshell
#997
Suspended
BKUK’s advice is a solid starting point. I’d go the same direction he did but maybe with a bit less droop (5.6f, 4.6r). Are you running an aluminum chassis?
#998
I might be mistaken, but didn't he say he was running VTA or USGT?
#1002
Suspended
I think the flex alum chassis is fine but carbon may help if you are still struggling for grip. I’d also recommend trying your Sorex 24s over the Sweeps.
#1003
well, I won last night. Don’t have the springs listed above, but dialed more camber in, and went up to 2mm spacer under inner ball stud on front, and zero spacers in the rear. And the car came to life. I also lengthened the wheel base 1mm in the rear and that made a big difference getting off the corner.
now, just have to get some wheel time in with it now that I can drive it. And I have got to find a better motor, cause these guys can run me down on the straights. LoL
thanks for the tips guys. I do plan to get some springs because I think the car can be better with springs. I just don’t see how the kit springs would work on high bite black carpet. Seem way too soft to me for that. LoL
#1004
are there shock towers to run the car with SLP shocks? Or the 2017 or older T4 towers fit?
#1005
Can't you use the stock shock towers but mount the bottom eyelet to the lowest hole on the arm?
