Like Tree735Likes
XRAY T4'20 SPEC
Old 10-27-2020, 08:06 PM
  #961
KE4PJO's Avatar
Originally Posted by NEED-MORE-SPEED View Post
Hello Everyone... With the indoor season upon us I wanted to share my setups from this past weekends Halloween Classic in Cleveland, OH. I ran 17.5 TC also Stock Spec TC.... Stock Spec TC we ran the MOTIV USGT 21.5 Closed Timing Motor
Cars worked well all weekend... 17.5 was able to TQ/finish 3rd - Stock I qualified 2nd and finished 2nd
17.5 Set Up: https://setup.teamxray.com/sheet/view?userSheetId=19246
Stock Set Up: https://setup.teamxray.com/sheet/view?userSheetId=19247
If anyone has any questions please let me know...
2* outboard toe? That can't be right...
KE4PJO is offline
Old 10-27-2020, 08:11 PM
  #962
KE4PJO's Avatar
Originally Posted by freebird View Post
Marc; Rear roll center on Stock was the same was 17.5????? you left out 1.0 or .5 for the rear pin bushing
Thanks Carl from Apex.
RF-0.5 up and out with -.25 RF blocks
RF- 0.5 up and in
= 1.75 inboard toe...
KE4PJO is offline
Old 10-28-2020, 05:05 AM
  #963
Sortafast's Avatar
99% sure thatís using the 1* rear hubs
NEED-MORE-SPEED likes this.
Sortafast is offline
Old 10-28-2020, 07:14 AM
  #964
KE4PJO's Avatar
I know it was a "typo", Xray has never done a 2* rear hub.
NEED-MORE-SPEED and Sortafast like this.
KE4PJO is offline
Old 10-28-2020, 07:46 AM
  #965
It says right in the comment section that he's running 1 degree in the hubs and 2 degrees in the pins (arms).
sps3172 is offline
Old 10-28-2020, 12:07 PM
  #966
NEED-MORE-SPEED's Avatar
Hello Everyone... To clear up any misunderstanding regarding the settings on the rear toe, that was my mistake and the setup sheets should now be accurate.
* 17.5 was running 2 degree on the pins (ARMS) and 1 degree hubs for a total of 3 degrees
* 21.5 stock was running 2 degree on the pins (ARMS), 1 degree on the hubs and -.25 split blocks for a total 2.75 rear toe
My apologies for the inaccurate setup sheet but is correct now.
KE4PJO likes this.
NEED-MORE-SPEED is offline
Old 10-28-2020, 12:12 PM
  #967
Correct... Rear roll centers were the same on both cars. Those pin settings is what's working best for me and seams to be working from the multiple tracks I've been to recently
freebird likes this.
Old 10-28-2020, 12:28 PM
  #968
R Dodge's Avatar
Xray did produce 2į uprights but they were aluminum and had 4 camber link positions. I donít believe there are many of them left out there though. It is something Iíve wanted to try on black carpet but havenít been able to make it happen. ARS seems like a good enough tuning option instead.
NutDriver and Sortafast like this.
R Dodge is offline
Old 10-28-2020, 01:09 PM
  #969
BEMO2019's Avatar
If I recall Trinity made 2į rear hubs as well.
BEMO2019 is offline
Old 10-28-2020, 01:34 PM
  #970
KE4PJO's Avatar
Forgot about those...
KE4PJO is offline
Old 10-28-2020, 01:55 PM
  #971
Super Moderator
Marcos.J's Avatar
Trader Rating: 221 (100%+)
they still have one on their website
Marcos.J is offline
Old 10-28-2020, 02:13 PM
  #972
BEMO2019's Avatar
I thought so as well but was unable to find them. They must have recently gotten removed.
BEMO2019 is offline
Old 10-31-2020, 07:04 AM
  #973
mocrawlin's Avatar
Trader Rating: 23 (100%+)
Originally Posted by mocrawlin View Post
Well, took some rear droop out and it was better for sure. Body helped quite a bit really. Actually had to turn the dual rate up a little. Went up to 5000 diff fluid and it was pretty good. Ended up TQing in the second round of qualifying and lead the race till the last 2 laps and just have the race away. LoL oh well, it was fun.
so, next week we donít race on road, so, I have 2 weeks to rewire and reposition the esc and reciever like itís meant to be. I was in a hurry and didnít have any wire to put the esc behind motor, so itís in front and I think the weight from esc in the rear, will help a lot. So, I look forward to racing again in a couple weeks! Thanks for the tips guys. The droop adjustments definitely helped.
well, had a club race last night. After putting electronics where they are supposed to be the car was much better. Right off the bat the rear was stuck and pushing the front. And made some changes and got it handling pretty good for the main. Finished 2nd. Now I think I need to work with shock oils to really fine tune it. So far, I am liking it.
anyone have any idea on what the Ď21 will have over the Ď20?
mocrawlin is offline
Old 11-05-2020, 07:34 AM
  #974
They put up a video about it this morning. No real shots of the car, but they said 8mm steering swing arm, black shocks, new top deck (didn't say split) new motor mount and new chassis plate w/o short arm holes. Doesn't sound like there's anything that would get me to upgrade since I pretty much have all option parts now for all my cars. I can live without black shocks (doubt black shocks would be in the upgrade kit). The LCG conversion seems better, but I doubt either would be faster for a club racer. Oh and finally a better battery mount, but again already got that.
ActiveShooter is offline
Old 11-05-2020, 10:28 AM
  #975
Perhaps the conversion kit or all new kit will be better for a club racer. With the updated RF suspension blocks, revised motor mount, top deck and chassis plate. The Factory guys who had part in testing are claiming more steering, more traction and most of all, an easier driving platform over the 20.
