Like Tree735Likes
XRAY T4'20 SPEC
Old 02-04-2020, 05:56 AM
  #706
Buckaroo's Avatar
Just getting back into TC after a several year hiatus and I'm gonna go Xray for the popularity in my area and the continued factory support year in and year out. The last TC that I wheeled was a TOP Photon
What are the mandatory 'spares' to have on hand, and what are the 'must have' hop ups for XRAY cars?
Lonestar likes this.
Buckaroo is offline
Old 02-04-2020, 06:06 AM
  #707
Lonestar's Avatar
Originally Posted by daleburr View Post
I also glue the bearings into the alu bellcranks. I use a small amount of blue threadlock (loctite) on the outer edge of the bearing. Gets rid of the play, but you can still remove the bearings when needed.
I was going to tear the steering apart for the Nth time again tonight, so I will do that too... a tiny tiny amount of CA should do I guess (we don't have permatex here)
thanks guys!
Paul
Lonestar is offline
Old 02-04-2020, 06:10 AM
  #708
Lonestar's Avatar
Yeah, Top Photon!
Spares - c-hubs, front spindles, rear spindles. They do break (c-hubs) or strip threads (spindles) if you crash hard enough but I've had whole seasons since the T3 '12 when I wouldn't break one single part. But it doesn't hurt to have a couple of spares I guess
"mandatory" hopups: 2.5-2.8 prog springs fronts, 2.6 and possible 2.7 rears. Crash brace for the T4'20, included if you get a '19 (please don't get us started again haha). Some spare alloy M3 washers (1.0, 1.5, 2.0mm...) for setup. And that's it, really... you do pay a lot of money to get the kit, but you get your money's worth, with possibly the most reliable car on the market today
Lonestar is offline
Old 02-04-2020, 06:58 AM
  #709
Buckaroo's Avatar
What's the difference between Xray HARD and GRAPHITE parts? Hard have a little more 'give' and Graphite stiffer but more brittle?
Buckaroo is offline
Old 02-04-2020, 07:04 AM
  #710
It's more about flex. A tuning option. Graphite being the hardest, and yes, more brittle. But still hard to break.
Buckaroo and Ggrant like this.
Carnage9270 is offline
Old 02-04-2020, 09:31 AM
  #711
mschumi101's Avatar
Trader Rating: 30 (100%+)
I would also pick up a few front arms. I’ve had a few crack at the horseshoe part around the Chub, just past the hinge pin where it gets really thin. Not a DNF, but Makes for a very poor handling car! I usually run the Hard arms as the graphite crack easier.
mschumi101 is offline
Old 02-04-2020, 11:09 AM
  #712
Buckaroo's Avatar
OK. How do I tell the difference in Xray springs. Is it in wire thickness or etched on the spring somewhere? Cross reference chart?
Buckaroo is offline
Old 02-04-2020, 11:47 AM
  #713
Lonestar's Avatar
You're Welcome !
Lonestar is offline
Old 02-04-2020, 12:07 PM
  #714
R Dodge's Avatar
the spring rate is etched on one end of the spring. It is pretty small but should be easy to see (at least when new)
Buckaroo likes this.
R Dodge is offline
Old 02-04-2020, 05:41 PM
  #715
tony q's Avatar
Trader Rating: 20 (100%+)
Did anybody try out the rcmaker top deck for the T4 20? Let me know how it handles..
tony q is offline
Old 02-04-2020, 05:46 PM
  #716
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
Tried it the other day car definately flexes more and feels more direct with it (on outdoor asphalt) only did a few laps but I can see it being useful when grip is low.
Not essential, but a handy tuning aid to try
nexxus is offline
Old 02-04-2020, 07:50 PM
  #717
tony q's Avatar
thanks I guess it won’t work on black carpet
tony q is offline
Old 02-05-2020, 04:17 AM
  #718
KE4PJO's Avatar
it works fine on the black carpet. I purchased the top deck just for easy removal of top deck, and I was properly surprised with quicker lap times...
KE4PJO is offline
Old 02-05-2020, 12:00 PM
  #719
Buckaroo's Avatar
Sorry to be an Xray newb and a pain with questions. Rear Toe: Kit includes 0degree rear hubs, basic assembly shows 0 rear toe, but basic set up sheets show 3degrees rear toe. Is this achieved with hubs, eccentric bushing placement, or a combo of both?
Buckaroo is offline
Old 02-05-2020, 12:21 PM
  #720
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Perfectly reasonable question. You change toe mostly by choosing combinations of the eccentric bushings. Page 15 of the assembly manual talks to this.
The standard setup is 3 degrees (bushings with centre dot), which is a function of the location of the mounting blocks, so the bushings are the tuning mechanism from there. You can also adjust rollcenter/anti-dive with the bushings.
PDR is offline
