Like Tree735Likes
XRAY T4'20 SPEC
Old 02-03-2020, 06:55 AM
  #691
I had the same problem.
1. Time to get new tires. - Use SXT minimally. 3 min soak max and wipe off. This will slow the bloat, but not eliminate it. Break tires in with SXT on a rag and a drill. "Smoke em"
2 Use the lower hole on the arm. If you do this you will need to flip the ring that adjust the spring rate.
3 Just run at 6mm and take out some rear toe. I usually replace the tires when grip comes up so much that I cannot drive effectively. It seems that worn VTA tires have more grip than new. I do not find rear as problematic as front.
Jsaves likes this.
ryan391 is offline
Old 02-03-2020, 08:18 AM
  #692
Lonestar's Avatar
2 Use the lower hole on the arm. If you so this you will need to flip the ring that adjust the spring rate.
I don't run VTA but it's always good to learn...
"spring rate" - can you explain?
thanks!
Paul
Lonestar is offline
Old 02-03-2020, 08:24 AM
  #693
Lonestar's Avatar
On another note - do you guys have a quick fix to remove slop from the alloy-alloy steering assembly? Most of it seems to be in the bellcranks-to-bearing assembly... Not very Luxury Premium if you ask me
Thanks!
Paul
Lonestar is offline
Old 02-03-2020, 09:00 AM
  #694
The kit comes with a spacer for that. There's an aluminum option as well. I'm using the plastic ones that came with the kit and don't have any of that. Or are you referring to the steering plate bearings?
On a personal note, I think removing a lot of the play in the car makes it drive a little funny. I prefer the little bits of play here and there.
Carnage9270 is offline
Old 02-03-2020, 09:07 AM
  #695
thanks!
Paul
He means the collar on the shock where you adjust your ride height. flip it upside down and you can adjust it further down the shock body.
I've been using the SLP shocks on mine with the lower holes on the arms. Really liking how it feels on the tracks I run at.
Old 02-03-2020, 11:36 AM
  #696
Lonestar's Avatar
Ok thanks - still confused about spring rate tbh...
Lonestar is offline
Old 02-03-2020, 11:37 AM
  #697
Lonestar's Avatar
Thanks - I'm talking about the two alloy bellcranks being sloppy on their steering posts (and sloppier than the plastic parts actually, the bearings float in the alloy arms it seems as opposed to being a bit more snug in the stock plastic parts.
Agree with some slop being needed - there is just too much on my luxury premium's machine steering imho...
Lonestar is offline
Old 02-03-2020, 12:55 PM
  #698
Zerodefect's Avatar
Glue them in with a dab of Permatex.
Lonestar likes this.
Zerodefect is offline
Old 02-03-2020, 01:12 PM
  #699
Not using the correct term, but the ring you turn on the shock to adjust the spring.
ryan391 is offline
Old 02-03-2020, 01:50 PM
  #700
Lonestar's Avatar
Glue them, really?!?
Lonestar is offline
Old 02-03-2020, 01:52 PM
  #701
Lonestar's Avatar
On another note
Got to love how this thing is balanced just by being symmetric on the spring collars
NutDriver likes this.
Lonestar is offline
Old 02-03-2020, 03:14 PM
  #702
yeah, the kit comes with 2 plastic spacers that go in between the 2 bearings. Should take all the slop out.
Old 02-03-2020, 03:47 PM
  #703
Jsaves's Avatar
I tried lowering the shock at the tract, but time was not with me. I found the shocks to short because of they would let the arms hit the droop screws.
So you lengthen the shocks out? Also would the new shock towers help the problem since they are 3mm lower?
Thank you and God Bless,
Jsaves is offline
Old 02-04-2020, 01:35 AM
  #704
Lonestar's Avatar
whoopsie, I had forgotten to take these out of the plastic bellcranks when I replaced them by the alloy ones... Thank you!!! that might not fix all the radial slop but it should at least remove some of the axial one...
Thanks again for the reminder
Paul
Sortafast likes this.
Lonestar is offline
Old 02-04-2020, 01:57 AM
  #705
daleburr's Avatar
Paul
I also glue the bearings into the alu bellcranks. I use a small amount of blue threadlock (loctite) on the outer edge of the bearing. Gets rid of the play, but you can still remove the bearings when needed.
Lonestar and Sortafast like this.
daleburr is offline
