Like Tree735Likes
XRAY T4'20 SPEC
Old 01-17-2020, 04:55 AM
  #676
Originally Posted by DirkW View Post
Panaracer.
Thanks for the tip-in.
mooby64 is offline
Old 01-20-2020, 07:35 AM
  #677
TeamGPT88's Avatar
Trader Rating: 15 (100%+)
Default Sway bars
Will any of the older T4 sway bars work on the 20 model?
TeamGPT88 is offline
Old 01-20-2020, 10:21 AM
  #678
DirkW's Avatar
The rear ones are the same as before, fronts are new.
Lonestar likes this.
DirkW is offline
Old 01-20-2020, 10:49 AM
  #679
TeamGPT88's Avatar
Old 01-21-2020, 12:34 AM
  #680
Lonestar's Avatar
Keep in mind the bulkheads are closer too, hence the stiffer 1.4F/1.3R kit setup than the past 1.3F/1.2R
Lonestar is offline
Old 01-21-2020, 01:48 AM
  #681
Skiddins's Avatar
It's been 1.4/1.3 for a few years now. If you want the same effect (due to the longer arms, not the bulkheads) you need to go up to 1.5/1.4
XSRCdesign likes this.
Skiddins is offline
Old 01-21-2020, 05:01 AM
  #682
Trader Rating: 33 (100%+)
Do sway bars work differently than shocks, in regards to pivot points? With longer arms, the length being added inboard and not at the wheel, and the same shock mounting position, the wheel rate goes up. This is because the wheel has less leverage on the inner pivot point because the shock has moved out relatively speaking. I would think it would be the same with a sway bar.
trilerian is offline
Old 01-21-2020, 07:22 AM
  #683
CristianTabush's Avatar
You are correct, longer arms call for softer springs and bars to get the same wheel rate.
I will say that the wheel rate change with the new longer arms is pretty small though, so the change in rate of spring and bar is probably more like a half or a third of a mm bar.
CristianTabush is offline
Old 01-26-2020, 09:35 AM
  #684
Jsaves's Avatar
Default Pinion
Hey Racers,
First Xray, having fun building the T4 20, but problem with pinion adjustments. I will run this car in USVTA and we use smaller spurs and large pinions. Having issues getting to the grub screw of the pinion when it is on the mounted motor. Ideas or tricks greatly appreciated.
Thanks and God Bless,
Jsaves is offline
Old 01-26-2020, 09:40 AM
  #685
DirkW's Avatar
Yes, that can be tricky sometimes. Wasn't easy with the previous models, but it seems it's even harder with the '20 to get an angle where you can still get to the screw, If all else fails, remove the top deck...
Jsaves likes this.
DirkW is offline
Old 01-26-2020, 12:43 PM
  #686
XSRCdesign's Avatar
Originally Posted by Jsaves View Post
Hey Racers,
I seem to have the best luck with the set screw in the 10-11 o’clock position. I usually can sneak my driver in that way. (Set screw out)
Jsaves likes this.
XSRCdesign is offline
Old 01-26-2020, 05:53 PM
  #687
Hey Racers,
I have been using a 1/16 ball end hex driver for years. Arrowmax makes one.
Jsaves likes this.
Old 01-27-2020, 07:40 AM
  #688
Hey Racers,
Loosen the motor screws so you can tilt the motor. This way you can get at the pinion set screw.
Jsaves, sagejyoung and NutDriver like this.
mooby64 is offline
Old 02-02-2020, 02:08 PM
  #689
Jsaves's Avatar
Default Ride height
Hey Racers,
I have a T4 20 in USVTA and with those tires I cannot get the ride height below 6mm in the rear. The shock collars are all the way up too.
Ideas?
Jsaves is offline
Old 02-02-2020, 05:05 PM
  #690
Chris Adams's Avatar
Hey Racers,
Ideas?
Our guys are running the lower shock mounting position and are able to get the proper ride height.
Jsaves and Sortafast like this.
Chris Adams is offline
