Like Tree735Likes
XRAY T4'20 SPEC
Old 12-31-2019, 02:29 PM
  #646
quantum's Avatar
Originally Posted by 0010 View Post
I just built my '20 and had to really tighten the rear belt to keep it from hitting the motor mount. I would normally run the rear belt much looser. I am wondering if the drag from a tight belt will be better or worse then the drag from the belt hitting the motor mount. What do you think?
I left the front belt loose, but should I tighten it up to match the rear belt or not?
Thanks!
to avoid rubbing against the motor mount, install a bearing on the other side of the batt stopper. Works just like a belt tensioner
quantum is offline
Old 12-31-2019, 03:30 PM
  #647
Originally Posted by sps3172 View Post
There was much discussion on this point (rear belt contacting the motor mount) when the kit first came out. My understanding is that because the contact occurs on the slack side, there is little consequence. I remember someone mentioning that they had quite a few packs through the car and the logos were still intact. I'm thinking if there was any significant friction, the logos would have been rubbed off.
Thanks! I will loosen the belt back where I like it!
0010 is offline
Old 01-01-2020, 01:00 PM
  #648
Jordyannie's Avatar
Does this apply for the ‘19 model as well?
Jordyannie is offline
Old 01-02-2020, 05:58 AM
  #649
no
freebird is offline
Old 01-03-2020, 04:06 AM
  #650
Darren Stoner's Avatar
Originally Posted by gigaplex View Post
How many pages is this argument over a single bumper brace going to go on for?
We can probably milk it for another 7 pages. I love reading some good complaints first thing in the morning lol
Lonestar and compRacer like this.
Darren Stoner is offline
Old 01-05-2020, 09:57 AM
  #651
Zerodefect's Avatar
Building this car for USGT.
Any idea what pinion and spur to start with. Slighty large indoor, crc black carpet track. Any different springs needed?
Zerodefect is offline
Old 01-05-2020, 01:33 PM
  #652
XSRCdesign's Avatar
using the Gravity/spec motor? 92-96 range depending on desired FDR
XSRCdesign is offline
Old 01-05-2020, 01:43 PM
  #653
Zerodefect's Avatar
Yeah we're running the new spec motor.
Old 01-05-2020, 07:48 PM
  #654
XSRCdesign's Avatar
I’m currently at 96/54 but it’s the back of the motor mount. I picked up a few smaller spurs in 1 tooth increments.
Zerodefect likes this.
Old 01-06-2020, 06:58 AM
  #655
AlexPate's Avatar
Trader Rating: 19 (100%+)
Thanks!
imo front belt should always be tighter than rear, having front belt looser will cause rear wheels to spool up sooner and cause over rotation on power. I don't think he belt rubbing on the motor mount will be an issue but if you are concerned they do have a belt tensioner you can install
AlexPate is offline
Old 01-06-2020, 09:22 AM
  #656
damn. I'm not running the "spec" motor yet as it hasn't arrived. but I was wondering the same.. currently with the r1 21.5 I'm geared 47/96.. you think I'll go up 5+ teeth on the pinion with the motor swap, seems substantial
Old 01-06-2020, 10:04 AM
  #657
bighurt98's Avatar
Default gearing changes
I run on smaller track! The motor has a lot of torque. I was running 96/51, 3.576 FDR. This weekend went down to 90/48, FDR: 3.562 to start. Then experimented with 90/49 (where I ran most day 3.49), was very happy across the board. Another driver tried 90/50, FDR: 3.42. That was similar, but thought might be losing on the infield, but lap times were maintained and more consistent for him. AS the track gets larger, I have heard being 3.2-3.4. You will need to adjust to your liking.
bighurt98 is offline
Old 01-06-2020, 10:29 AM
  #658
Zerodefect's Avatar
Thanks for the gearing tips.
Do you run the 23mm thick packs? Or the thinner LCG 18mm packs?
http://shop.sunpadowusa.com/index.ph...&product_id=50
Old 01-06-2020, 12:19 PM
  #659
bighurt98's Avatar
Default Pack weight!
Sunpadow 7.4V 5300mAh 130C/65C LiPo Battery Top Series Part Number S653065
I personally run a LCG pack at 272g. Some say go to larger pack like 8000,8400, etc. then re-balance car. Gives better run times late in the run. Will try new McClan 8500, 305g or so which be a good option.
Old 01-06-2020, 01:20 PM
  #660
Zerodefect's Avatar
Thanks. I'll try to find a battery around 270g's. The ULCG battery is only 230ish, so that's 6 extra steel weights, and that's a bit much.
I'm going to try a heavy SMC aluminum ESC first. I have an extra Tekin RS spec available if I need a lighter ESC.
