Like Tree735Likes
XRAY T4'20 SPEC
Old 12-21-2019, 05:47 AM
  #631
Mr. Bubby's Avatar
Originally Posted by porsche928gs View Post
Moving on then to the very narrow choice of pinion gears for stock racing🤣🤣🤣🤣🤣. That's ok you can buy a spacer for your motor to make it work. of course this only affects certain motors. Also you can buy the rcmaker top deck
Yup, just ordered both versions. Put the 1.6 on in the beginning of the race day, then maybe change to the 2.0 after the 2nd qualifier (after the traction comes up a bit). See how it goes. According to RCMaker there should be no issues with any combination of the Spur/Pinion
Mr. Bubby is offline
Old 12-21-2019, 03:36 PM
  #632
porsche928gs's Avatar
Yes. with this top deck you won't have any issues with gearing combinations.
porsche928gs is offline
Old 12-21-2019, 04:51 PM
  #633
ottoman's Avatar
Anyone know who has the optional lower shock towers in stock???
ottoman is offline
Old 12-21-2019, 06:24 PM
  #634
Team EAM
Trader Rating: 79 (100%+)
Not available in the US yet.
EA
EAMotorsports is offline
Old 12-22-2019, 12:57 AM
  #635
Lonestar's Avatar
So much for symmetrical Flex
Lonestar is offline
Old 12-22-2019, 09:11 PM
  #636
Just like the Schumacher MI7.
Old 12-23-2019, 01:06 PM
  #637
Riketsu's Avatar
Trader Rating: 33 (100%+)
Whenever I see aftermarket top decks and chassis, my thought process goes: "Damn, Xray spent 20+ iterations of each with testing in between, just to have someone else crap out a top deck / chassis out of thin air.".
Lonestar, Airwave and XSRCdesign like this.
Riketsu is offline
Old 12-23-2019, 10:11 PM
  #638
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
I noticed with the Awesomatix that the RC maker decks break a lot easier than a stock one I've done 3 "flex decks" on my a800 and in 5 yrs have never broken a std (pre mid mount) top deck and only once cracked a mid mount top deck. To be expected when any force has to go along a single line of CF rather than being split between 2
nexxus is offline
Old 12-27-2019, 11:01 AM
  #639
spring71's Avatar
Xray T4 2020 Kit and Parts are arrived today at TQ RC Racing.
https://www.tqrcracing.com/shop/prod...?s_maker_id=24
FYI, Thanks.
Mr. MR4, team green and NutDriver like this.
spring71 is offline
Old 12-30-2019, 10:58 PM
  #640
TryHard's Avatar
How do you know that those who have 'crapped out stuff from thin air' havent tested a few designs and iterations to get ideas right?
corney_01 and gigaplex like this.
TryHard is offline
Old 12-31-2019, 05:48 AM
  #641
anyone play t4 20 for blinky race? Is short rear belt car better for blinky?
tommy1030 is offline
Old 12-31-2019, 07:02 AM
  #642
bertottius's Avatar
Trader Rating: 23 (100%+)
I would say the mid motor car is better all around. My mid motor is faster than the my 19. Seems to turn better
bertottius is offline
Old 12-31-2019, 12:35 PM
  #643
I just built my '20 and had to really tighten the rear belt to keep it from hitting the motor mount. I would normally run the rear belt much looser. I am wondering if the drag from a tight belt will be better or worse then the drag from the belt hitting the motor mount. What do you think?
I left the front belt loose, but should I tighten it up to match the rear belt or not?
Thanks!
0010 is offline
Old 12-31-2019, 12:55 PM
  #644
Thanks!
There was much discussion on this point (rear belt contacting the motor mount) when the kit first came out. My understanding is that because the contact occurs on the slack side, there is little consequence. I remember someone mentioning that they had quite a few packs through the car and the logos were still intact. I'm thinking if there was any significant friction, the logos would have been rubbed off.
Lonestar likes this.
sps3172 is offline
Old 12-31-2019, 01:26 PM
  #645
GeorgePravata's Avatar
Trader Rating: 136 (100%+)
If anyone is looking for a brand new for sale check out the for sale post.
GeorgePravata is offline
