XRAY T4'20 SPEC
#481
The build continues and is almost over
Couple of key informations:
- the battery mounting system holes are the same, so if you have an after market system installed on a previous car you can reuse it
- it looks like body mounting positions are the same too but still tbc
- the rear anti-roll bars are the same reference as before, not the front, and the design is not compatible
- the pillow balls let's go into the plastic shock top and bottom ends unfortunately are not threaded all the way through anymore. Which combined with the grub screws that are too long and 10mm instead of 8 creates issues.
Overall, the car looks fantastic!
#482
Why does XRay include crap they know we are going to have to upgrade. Why not just put a 96 tooth Spur in the Kit. It is right in the middle. Would not have cost anymore, or any less.
#483
My build was great. Had the minor issues listed aleady. A-Arm grub for the shock mount was too long, button head screws for the shock mounting to shock tower were also too long. Also, I recommend attaching the middle pully/spur combo on before the diff and spool are added as they fall out when putting it in, lol. First run on the car and I was able to turn the first sub 11 second laps on the layout. Car has a lot of turn in and carries good corner speed, just a little on edge for me with med/high traction on black carpet but a great starting point.
#485
Honestly, at this level of kit from Xray or any other manufacturer, why include a spur gear at all since that is ultimately decided by class, motor size, spec rules, etc. I really think it would be better to not include any oils for the shocks or diff as those are track and traction dependent. I have dozens of tubes and bottle of unused “included in the box” oils.
if your not going to include tiress and a body (like they were in the old days) because it’s too subjective, Spurs and oils are as well, let go ahead and cut those out
#486
#487
#490
They have to clear the new pulley assembly
#491
Thought I'd wait until I had driven the new car before I commented on it. So here's my opinion. I didn't realize many of the issues that I've read about except for one. The top deck issue was the only bothersome thing. I worked around that by trimming the it about 0.5 mm, I did both sides to try to even the flex as best I could. But after putting it on the track, this car is great. My lap times improved without pushing the car at all, easily 1.5-2.0 tenths per lap (3 1/2 seconds over the 6 minute run). My only "complaint" would be the motor mount, I'd like to see it extended maybe a mm or so.
#492
