Old 12-22-2002, 08:51 PM   #61
kevin2's Avatar
Send a message via AIM to kevin2
Default DANG
I just got that ionic last month. RATS!Just wundering why do i need a charger that will go up 8v?
kevin2 is offline   Reply With Quote
Old 12-22-2002, 09:37 PM   #62
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Amps not Volts...
Highest amp charge allowable by battery gives the highest voltage. Higher voltage = more power. More power = faster speed.
If you are only bashing around or not racing then the ionic and everything else you have is just fine. All the higher end gear is mainly for shaving that 1/10th of a second off your laptimes....
ChristopherKee is offline   Reply With Quote
Old 12-22-2002, 09:42 PM   #63
kevin2's Avatar
Default im dumb
amps duh! sorry i forgot
Old 12-22-2002, 09:44 PM   #64
kevin2's Avatar
I race carpet on road with my TC3 in the sportman class.
Old 12-23-2002, 04:05 AM   #65
I still say get a couple of decent packs, you do not need top line gear to go well, your charger and ESC will suffice until you are a good enough drive to out perform the equipment you have. Make sure you take care of your packs and keep your motor in top condition, it will make much more of an effect than a higher end speedie, or a charger capable of delivering more amps.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 12-23-2002, 09:46 AM   #66
Trader Rating: 24 (100%+)
Kevin2 ......Frustrating, isn't it ??!! We've all been there ?? I don't think you mentioned....Are you winning or competitive in your class ?? If so...the equipment you have is fine. If not..you have to decide whether it's YOU who needs work or your equipment. If you really think it's your stuff...then Yes..get better stuff. See what the other guy's in your class are running. Let us know.
Just to make things more exciting...I'd like to throw my 2 cents worth in. If you haven't tried one of the Mtroniks esc's....You should !!! The M3 Cubic is fantastic. Not saying it's any better than all the others but just wanted to join everybody with a shameless plug for my favorite !!
Evoracer is offline   Reply With Quote
Old 12-23-2002, 11:22 AM   #67
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Kevin - Your charger should be fine for you untill you feel you are ready to make the move up to Stock.
Your new radio should help you out a little bit with the control aspect, and I didn't get a chance to watch you last week. MAke sure I watch one of your heats. I should be racing on the 28'th.
I'll probably be getting a couple new packs either next week, or the weekend after the first. If you want a couple of my race packs, I'm sure i could give you a good deal on them.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 12-23-2002, 12:36 PM   #68
kevin2's Avatar
Default Thanx guys!
Thanx. i am doing ok in my class i took 2nd of 8 2 weeks ago but i almost won.I want a new ESC for a couple of reasons.1 I have the money and i would be buying in a couple of months from now any way.2 my friend just got a xxx-s for 100 bucks and i am giving him my old equipmeny.He need s a ESC before he can race so i think if i get the new ESC now i can buy a couple of sets of batts in a couple of months or a lath and my friend can drive his car.I cant get a matched cells cuz my dad wont let me get them even if i have the money for them right now he cuz he says that i dont need them untill i move up to the stock class.
-Thanx for the help Kevin
Old 12-23-2002, 12:55 PM   #69
kevin2's Avatar
sorry about the typos i was in a hurry i had to leave.Most people have the rtr car and a couple of kids have the FT team.I have the racer with threaded shocks and a roll bar.The new radio i got helped a bunch i could drive straight and not have to worry about glitching.in the first practice i blew up a P2K2 pro motor so i put my monster motor in and my car was much faster but the couple of kids with the FT team have all realy good stuff like 3PJ radios in the sportman class.And i barley beat 2 of the kids cuz they tangeld on the last lap.So i took 2nd i have no idea what ESC there using though but if i get a new ESC i want one that i wont have replace for a LONG time.and i bought take off tires and my 4 month old sorex tires were better then the brand new take offs.so from now on im only buying sorex.My driving is pretty good not the best but pretty good.
Old 12-23-2002, 01:39 PM   #70
RCTech Member #2
TSR6's Avatar
Kevin - Go with the TakeOffs man! Especially if you are running the Novak USTC race in Jan. You can't beat the price on the tires. $32 (?) for a set of four! The sorex Rubber ONLY costs over $30 including tax. Then you have to include the $10 for inserts, and the $8 for the wheels themselves. It's just not worth it when the Take Offs run just as well.
With the TakeOffs, make sure you get a good scuff run on them before you accually use them in a heat. I know when I first ran them, I was sliding all over the place the first practice. After about 5 laps, I came in, re-saused them, and finished off the battery. After that, the tires worked well, although they are shot now!
You don't need a lathe. If you see me cutting my motor, just bring your armature over, and I'll cut it for you.
Edit - I just estimated the cost of a full set of Sorex. about $49. Take Off, With Racer Discount @ Trackside ends up being like $32, preglued..
Troy
RCTech Member #2
Old 12-23-2002, 02:28 PM   #71
kevin2's Avatar
Default im a idot
TSR6-very true by the time i but 4 sets ill save 100 bucks! with that i can some 3300 or some 3000..I probley wont race on the 28th but ill be there for the new years race.sorry im a idot what is to scuff the tires?
Old 12-23-2002, 03:03 PM   #72
RCTech Member #2
TSR6's Avatar
Default Re: im a idot
In an effort to keep this thread on topic ( heh... Whoops! ) I'll PM you.
Troy
RCTech Member #2
LRP Quantum Competition 2.... QC2 Team Girth R/C Items: For Sale/Trade 5 06-01-2006 03:46 AM
LRP Quantum Competition Jeremy Blair R/C Items: For Sale/Trade 4 05-04-2006 07:37 AM
LRP Quantum or Quantum 2 competition Core Creations R/C Items: Wanted to Buy 1 10-03-2005 11:56 AM
LRP QUANTUM COMPETITION 2 mikep R/C Items: For Sale/Trade 6 06-30-2005 07:11 PM
LRP Quantum Competition 2 Accord Electric On-Road 14 07-30-2003 07:59 AM
