Old 03-04-2006, 05:01 PM   #16
jrxsracer's Avatar
Trader Rating: 7 (90%+)
Ok, so it's not like it will affect performance by discharging at 10 amps versus 30 amps then right?
So for the time being, I could get by with the 10 amp from the Pulsar?
jrxsracer is offline   Reply With Quote
Old 03-04-2006, 05:16 PM   #17
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Better off not to discharge them then just charge, run, charge, run, charge, run!! If you can, run them so far lol that the car will not go! lol
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 03-04-2006, 05:27 PM   #18
jrxsracer's Avatar
So you say not to use the Pulsar 10 amp discharge then?
Old 03-04-2006, 08:17 PM   #19
go to the smc thread and look for the latest info there on charging and discharging, imo, theres alot of bull crap being posted here.
and also be aware that battery care if different for off road and on road
Turtlemaster is offline   Reply With Quote
Old 03-04-2006, 08:35 PM   #20
Michal101's Avatar
Originally Posted by Merciless
It's commonly believed to be best to discharge at as close to a race simulated discharge current as possible. i.e 30/35amps
Personnely i can't see it being a really bad thing, if your only doing it at the end of using them.On the other hand if your trying to condition them you really need to be at 20amps minimum
Now, with that being said then what is the TRUE amp rate discharge of the Dyna-pulse or the Spintec? Sure, it gives you the numbers at the 30 amp rate...but what is truly discharging at ????
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Discharge Rate Question. wade7575 Electric Off-Road 18 02-29-2008 04:44 PM
Discharge Rate Compensation? avrcguy Electric Off-Road 2 11-21-2007 10:54 AM
is a 10amp discharge rate fine?? factory racer Electric On-Road 0 10-26-2005 09:58 PM
Discharge rate for 19T micros_rock Electric On-Road 1 04-23-2005 02:23 AM
Discharge rate differences/questions.. lee82gx Electric On-Road 3 02-14-2003 10:29 PM
