Old 03-03-2006, 08:45 AM   #1
Michael Barch's Avatar
Send a message via AIM to Michael Barch
Default Soldering ESC wires
I was wondering how to solder new ESC wires on my Novak GTS, there all connected on one circut (rod, board, whatever it is called). Not seperated holes for each wire.
I was just wondering exactly how to take the old ones out and install new ones. Reason Im doing this is because I cut my old wires too short and I want to run the wires under the chassis and directly to the battery. I would solder more wire to the existing wire, would that just be fine? Or would I lose alot of power?
Here is what a GTS looks like if you don't know.
http://h1071118.hobbyshopnow.com/Pro...OV1940-450.jpg
Thanks, Mike.
Michael Barch is offline   Reply With Quote
Old 03-03-2006, 08:55 AM   #2
jhigga15's Avatar
Just un-solder the wires, cut the wires to the length you want and solder it back in the correct place, just make sure that the + and Ė donít get mixed upÖitís that simple. For me I tend to hold the Iron on the bottom of the board and the wires almost pop out.
jhigga15 is offline   Reply With Quote
Old 03-03-2006, 09:31 AM   #3
Yeah, so hold my tip at the bottom of the board and the wires will come out? How much solder do I put? How would I apply it correctly? I want this to look pretty clean.
Old 03-03-2006, 09:40 AM   #4
This should help out CLICK
RCevolution is offline   Reply With Quote
Old 03-03-2006, 12:45 PM   #5
Thanks a ton!
Soldering wires to Mamba Max superlapS15 Radio and Electronics 2 04-13-2008 05:17 AM
Soldering motor wires on mm esc aggieboy Radio and Electronics 6 03-04-2008 05:13 AM
AMB PT - New Wires? jsmax Electric Off-Road 1 04-06-2007 09:33 PM
Wires!!! Tpg racer Electric On-Road 19 06-18-2006 06:21 AM
soldering wires on a V2 AEDave Electric On-Road 2 09-15-2005 11:41 AM
