Old 11-20-2008, 07:46 AM   #1081
Trader Rating: 21 (100%+)
oh right on now i have some figures to aim at.
I don't really want it >19000k as I'm going to be using it at nationals in a demonstrator class and the limit is 19,000 .
l337 is offline   Reply With Quote
Old 11-20-2008, 10:50 AM   #1082
rccardr's Avatar
OK, if you are limited to 19K at 7.2 volts (which is not such a fast motor) then start with a new Johnson 540J, part #53689 (not a Mabuchi- you'll get much better results with the Johnson) and just run it at low voltage (3-4 volts) with a slave motor (hook up the slave at reverse polarity so the race motor rotates in the correct direction) continuously for 3 or 4 days. Use comm drops on the comm (any light-colored comm drop works fine) and oil the bushings twice a day. That will loosen it up real nice and make it as fast as it will ever be without...enhancements.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 11-23-2008, 08:11 PM   #1083
What kind of enhancements are you talking about doc?
Matt Smith is offline   Reply With Quote
Old 11-23-2008, 11:38 PM   #1084
monkeyracing's Avatar
He'll never tell. Ancient Chinese secret!
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 11-24-2008, 05:35 AM   #1085
fleetmaster's Avatar
Trader Rating: 16 (100%+)
Doc, what is your preferred cleaning regime between rounds at a meet ??
I seem to have stumbled across a half decent motor and wish to keep it in good condition.
Cheers !!
fleetmaster is offline   Reply With Quote
Old 11-24-2008, 07:19 AM   #1086
fleetmaster u dont need to clean em. Just drive the crap outta the car and be consistent to be fast.......... oh and gear the sucker up
i used to be fast in 540..........................................
dangles is offline   Reply With Quote
Old 11-24-2008, 10:41 AM   #1087
rccardr's Avatar
I usually clean after 3 runs. Light comm drops, 2-3 minutes at 3-4 volts, then 3 quick shots of motor spray. Relube. Easy!
I've never lost.
Old 11-24-2008, 03:30 PM   #1088
Dangles,
I cleaned it up prior to last weeks racing and the car screamed.You were telling Princess to get out of my way if you recall.
It got progressively slower as the night went on.
I'll take your word on the last comment as the truth
Old 11-24-2008, 03:35 PM   #1089
Doc, i'll be sure to give it a clean out before the final.
We run three heats/one final.
Cheers.
Old 11-24-2008, 06:25 PM   #1090
doki71's Avatar
newbie question..
i have 2 silvercan motor.. 1 draws 1.7amp and the other 1 rdaws 2.4amps.. they have the same rpm. which is better from the two of them.? im planning to use one of them this coming weekend race.. thanks!
doki71 is offline   Reply With Quote
Old 11-24-2008, 07:56 PM   #1091
SirSwiftAlot's Avatar
Location: SOCAL the fastest mini cooper guys in the nation
I agree with Doc on his cleaning regiments I also do the same but a little added help to a pretty worn out motor is to take brasso and apply to the comm with a needled applicator and run the motor with a slave motor kooked up backwards so that the motor you are cleaning runs the correct direction. After running the slave motors for 2 minutes at 1.5 - 2 volts remove the motor and rinse with water till clean. Then run your motor at 1.5 - 2volts for 2 minutes, clean with motor spray and apply bushing oil to bushing. Here is something that also works well is after the bushing oil application run your motor backwards for 3 minutes at 3 volts you will also gain RPM but shhh don't tell anyone. Its a good idea to dyno your motor and see your results as you go through different procedures so you know what works for you and what dosen't. GOOD RUCK TO EBWEONE
Why do people park in a driveway but then drive in a parkway?
SirSwiftAlot is offline   Reply With Quote
Old 11-25-2008, 07:08 AM   #1092
how do i connect the slave and main motor together?
Old 11-25-2008, 07:56 AM   #1093
Originally Posted by doki71 View Post
newbie question..
Stock silver cans usually fall in the .9 to 1.1 amp range at 5v. Those 2 motors are very unusual or are not the Tamiya #53689. This is assuming the amp draw was measured properly.
In any case pick the one drawing 1.7 amps. The lower amp draw will give you a cooler running motor and will last the whole race w/out dropping off in performance.
Granpa is offline   Reply With Quote
Old 11-25-2008, 09:11 AM   #1094
doki71's Avatar
they are both johnson 540 motors.. tested at 7.2 volts.
thanks for the advise granpa.. ill use the one that draws 1.7amp for saturdays race..
Old 11-25-2008, 09:13 AM   #1095
joe of loath's Avatar
about 2cm of fuel tubing works well.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 02:44 PM
Silver Can (Mabuchi) Motor Tricks miller1990 Electric On-Road 1 03-06-2007 10:06 PM
Co27 motor tuning tips, hints, or tricks schmidt452 Electric Off-Road 16 11-08-2006 11:04 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 10:54 AM
