Old 01-10-2008, 06:45 AM   #841
Roadburn's Avatar
Default Hey guys
Hey Guys, I do have to admit for begginners that motors can seem complex. I remember when a friend and myself first hardwired a motor. It felt like we were doing brainsurgury. These pages are helpful but take it a bit of humor. I first started checking out the thread for tips but ya soon realize. That a bunch of these guys race together and like everyone, we all love bustin chops. For people who are not that knowledgable about motors 9 out of 10 times you will find someone helpful at the track. All motors have things in common and tips you learn from one style of racing. You find works on different motors. When Granpa mentioned dropping the motor I smacked myself. It was a tip I use for rebuildable stock motors. If you are interested in motors. Pick up some sort of small dyno like a Trinity Motor Monster will it will show you RPM and such. This way as you play you can see the changes in the motor an not have to guess. Not to get off track but if you do race stock motors. Go on Ebay and grab "Big Jim's Black Motor Book". Even though it is a little outdated, it is a great starting point.
Happy Racing All!!!
Roadburn is offline   Reply With Quote
Old 01-10-2008, 08:26 AM   #842
mep
mep's Avatar
Trader Rating: 40 (100%+)
While on the sbject of tapping motors... I've seen two motors bind up after a hard wreck in a M-03 caused the magnets to move. We figured out it was the magnets causing the binding, because after removing the motors & investigating, we found that tapping the motor on a table would cause the magnets to shift up & down after the impact. The binding would stop if the magnets were shifted back into the optimal position... but the magnets could easily be knocked back out & binding returned.
mep is offline   Reply With Quote
Old 01-10-2008, 04:41 PM   #843
RaceBucks's Avatar
What is the difference between these 2 motors from Tamiya: 7435043 and 7435079?
http://www3.towerhobbies.com/cgi-bin...?&I=LXGN28&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXPML4&P=7
Both look like 540 silver cans, but one is $16.50 and the other is $10.50
Thanks.
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
RaceBucks is offline   Reply With Quote
Old 01-10-2008, 06:29 PM   #844
Hebiki's Avatar
Trader Rating: 26 (100%+)
Thanks.
shiny one is just a "mabuchi" (i.e. slower).. the other one is a "J" (johnson, more RPM) motor which has more RPM. you want the "J"...
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-10-2008, 08:08 PM   #845
Thanks.
I'll defer to my more learned collegues, but you want the shiny one. Tower may be in error on their info on the motors. The grey one is what tamiya is putting in the newer kits and they are pretty much duds. Doc, Devin, or Brandon may have more insight into the differences.
Granpa is offline   Reply With Quote
Old 01-11-2008, 05:27 AM   #846
rccardr's Avatar
Last two posts are spot on. You can make the grey cans faster, but the J motor is a better starting point and they seem to last longer as well.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 01-11-2008, 02:51 PM   #847
Deaths-a-Bitch's Avatar
Default with motor
hi guys, just a quick question, just brought a durga buggy for the wife, the kit motor come shiny silver can with yellow/ green wires,, and seems bloody quick(heaps quicker then my xx4 with a johnson) so what turn is it? from memory it has tamiya stamped on it and not johnson/mabushi etc.. is it a 23 turn or still 27turn,,
thanks
Deaths-a-Bitch is offline   Reply With Quote
Old 01-11-2008, 03:48 PM   #848
joe of loath's Avatar
should still be 27t. the 23t ones are the black can ones.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 01-11-2008, 05:05 PM   #849
Trader Rating: 44 (100%+)
I've been rotating through a lot of different Tamiya kits lately, and have come across no less than 4 different silver can motors. There's the standard silver Johnson 540J motor, the stickered Mabuchi 540 with back endbell, the dull gray Mabuchi with a silver endbell, and the dull gray motor with the white plastic-looking wire retainers near the comm.
I would say the performance I've seen between them is about the same order as I listed them, at least "stock".
Now if I could just get ONE to run worth a darn!
M03R, M04L, TT-01R Type E, Midnight Pumpkin,
Lunch Box, CC-01 Wrangler, SC10.2FT,
SC10B, Traxxas Slash
minimadman2003 is offline   Reply With Quote
Old 01-12-2008, 01:00 AM   #850
Send a message via AIM to A-Ko
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 01-16-2008, 06:15 PM   #851
What's everyone using to polish the comms? I've been using brasso, but don't like the filmy residue it leaves behind. Chrome polish is even worse.
Old 01-16-2008, 11:16 PM   #852
oME
oME's Avatar
Default here's something
try a liquid metal polish dab it onto the comm and then clean it like a trophy so that it will shine at its best! Then spray with water or motor spray then pressurized air.
Itís not about winning the race itís about being on the race!
oME is offline   Reply With Quote
Old 01-17-2008, 12:30 AM   #853
James khoo's Avatar
Trader Rating: 15 (100%+)
Send a message via Skype™ to James khoo
Me too
James khoo is offline   Reply With Quote
Old 01-17-2008, 12:51 AM   #854
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Default 540 max temp
Hi all
Does anyone know what the max temp would be to run a 540 at.
Regards
Gary
GSM Storm is offline   Reply With Quote
Old 01-18-2008, 08:52 PM   #855
kidsid99's Avatar
Trader Rating: 53 (100%+)
In case you missed my point, I'll let you know what I've been playing with lately, which what effect comm drops may have. Base line rpm on this motor was 18,640. Comm had been cleaned with Brasso. Next the comm was polished with a chrome cleaner which can be found in most well stocked auto parts stores like Pep Boys. Rpm 18,900. Used Tribo and rpm dropped to 18360, but amp draw went up. Cleaned and polished and used a different comm drop. Rpm went down slightly and amp draw went up again. Sprayed motor out with motor spray, reoiled, but did not polish or clean. Rpm was 18,900. Ran motor for 5 min. at 7.2 volts. Rpm was 19,260. Waiting for the motor to cool so we can test it again. Suspect that the extra rpm was due to the motor being warm. So what does this all mean????
1. I've got more time than brains.
2. I have no idea.
3. Is this worth trying at the next race? You bet. 600+ rpm in just how you prep to race is well worth it.
Granpa,
Do you mind telling what you are using to get your rpm and amp draw? Cause I have been working hard on trying to get 600 extra out of mine. Just wondering what brand or type of dyno you are using.
Thanks in advance, Sid
kidsid99 is offline   Reply With Quote
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 02:44 PM
Silver Can (Mabuchi) Motor Tricks miller1990 Electric On-Road 1 03-06-2007 10:06 PM
Co27 motor tuning tips, hints, or tricks schmidt452 Electric Off-Road 16 11-08-2006 11:04 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 10:54 AM
