Old 11-19-2007, 04:38 PM   #586
Default mabuchi
hi,
mabuchis i think are designed for drills and other stuff. i believe designed so that as brushes wear, internal timing is retarded to compensate. meaning the motor is designed to keep same max rpm as the brushes wear down.
i may be wrong, but i think thats why it is faster in reverse rotation. the 0 degree timing is only if you look at it externally. its what happens to timing as brushes wear down...
enjoy.
rccartips is offline   Reply With Quote
Old 11-19-2007, 05:51 PM   #587
rccardr's Avatar
They actually have a little negative timing, which is why they run faster in reverse. Steve is correct, breaking in the brushes too long in reverse rotation will actually make the motor a little slower, and it will get worse as the motor is used.
I was just trying to build a motor to keep up with Doc
...and now you know exactly how foolish that was...
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 11-19-2007, 11:56 PM   #588
Is that why the motors get faster the longer you run them? Maybe they don't, but to me they seem to.
Granpa is offline   Reply With Quote
Old 11-20-2007, 04:16 AM   #589
joe of loath's Avatar
so why not break in in forward? then you egt the advanced timing in forwards?
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 11-20-2007, 05:28 AM   #590
rccardr's Avatar
Steps To Silver Can Enlightenment:
#11:
#14:
I've never lost.
Old 11-24-2007, 03:16 PM   #591
Default freeze spray
has any one used the freeze spray to cool the motors before racing if so where do you apply it , outside the can or inside it? and what is the best way to run in a new silver can motor???
top-timm is offline   Reply With Quote
Old 11-24-2007, 03:49 PM   #592
Hawk6's Avatar
Trader Rating: 50 (100%+)
#11:
#14:
Care to share steps #1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 12, 13, and anything after 14?
Hawk6 is offline   Reply With Quote
Old 11-24-2007, 03:56 PM   #593
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Exactly...a shred of info would be great! Something other than dip it in water...I think that has been covered...
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 11-24-2007, 04:41 PM   #594
Default help
read all the messages and tried most of them but the freeze spray never used has anyone????
the motor seems to be great for 3 mins but the last 2 it slows , i think it is getting hot and slowing it??
would a fan on top of the can help in keeping it cool.
what type of comm drops is the best for output ?
i run the mabuchi type of 540 motor
Old 11-24-2007, 09:02 PM   #595
rccardr's Avatar
Canned freeze works well in a very warm environment, but according to my test bench equipment it makes the motor live longer, not go faster. Yes, they do slow down somewhat as they get hot.
Step #1: Select the genetic mutants.
I've never lost.
Old 11-25-2007, 02:59 PM   #596
Does anyone know the differences between the silvercan and the blackcan motors??? I'd like to know whether the timing is different or is it just a different wind. How much different are the rpms and the amp draw????
Old 11-25-2007, 03:12 PM   #597
i think silvercans are 27t and black cans are 23t. maybe the timing is advanced slightly on the black cans...
Old 11-25-2007, 05:42 PM   #598
rccardr's Avatar
Correct on both counts:
Silver can = 27 turn, slightly negative timing
Black can = 23 turn, 8 degrees positive timing
I've never lost.
Old 11-25-2007, 06:22 PM   #599
Thanx for the info. From that I'm extrapolating, but can we expect at least
23 to 24000 and 1.5 amps from a decent blackcan????
Old 11-26-2007, 05:28 AM   #600
rccardr's Avatar
At what voltage?
I've never lost.
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 02:44 PM
Silver Can (Mabuchi) Motor Tricks miller1990 Electric On-Road 1 03-06-2007 10:06 PM
Co27 motor tuning tips, hints, or tricks schmidt452 Electric Off-Road 16 11-08-2006 11:04 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 10:54 AM
