Old 11-09-2007, 11:36 AM   #556
SirSwiftAlot's Avatar
Location: SOCAL the fastest mini cooper guys in the nation
We are not stupid you don't get 25,000 out of a johnson legally. BTW that motor sounds to be about 19,200 - 19,800 I can tell in the pitch you have'nt even begun to hit the high winding sound yet. But its very nice of you to share with us though. I will give you an A for presentation A for thought and F for proper documentation and support findings.
Why do people park in a driveway but then drive in a parkway?
SirSwiftAlot is offline   Reply With Quote
Old 11-09-2007, 06:28 PM   #557
Weasely's Avatar
Alrighty, i've read through pretty much the entirety of this thread and taken on board the most common 'voodoo tricks' to running in your johnson motor.
As it stands, the other lads in the class seem to poop all over me on the straights, and have just a tiny bit more torque as well. Since i was running no fan, and my motor was getting painfully hot due to overgearing, (burned one out in experimenting) and tight drive-belt most likley, i've gotten a fan, smaller pinions (aiming for an FDR around 4.5-4.8, since its apparently what other folks are using) i'm just trying to find the extra things that the other folks are doing, that i might not be - i reckon my racing line is improving, so now i'm hunting that extra bit of 'go'.
The point of my post though - I dont have a charger or motor management gear to run in my motor. What should i use to do it, in its place? Some batteries soldered together in a linear fashion? If anyone could shed some more light on the details of that - like just the same sub-c cells as what you'd use to power the car, or if this is even the right idea at all, it'd be much appreciated.
I've got a bunch of gear at hand to use, including a drill to try running-in as well.. I've got Team Orion Motor spray, Brasso, metho, turps, some thin oil (for a sewing machine i beleive)..
Just not sure what path of action to take from here on in, in seating those damn brushes right. I have two two-slot johnson motors - the sort with black 'endbells', one is more shiny on the can than the other, which i think a fella at the track mentioned one has softer brushes than the other (which i took note of).
Brakes only slow you down.
Weasely is offline   Reply With Quote
Old 11-10-2007, 03:33 AM   #558
kuanseng1981's Avatar
Trader Rating: 15 (100%+)
Well the video as i promise, anyway this is the 24000 rpm motor at 7.2volts
http://www.youtube.com/watch?v=KX0teQd4cUo
Friends come and go,
who's your friend nobody knows,
till the time than it will show,
who is friend who is foe.
kuanseng1981 is offline   Reply With Quote
Old 11-10-2007, 03:52 AM   #559
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
did you tweak your 540j?
it awesome!
hello miss, puwede pa bind?
nikkiesteban is offline   Reply With Quote
Old 11-10-2007, 03:54 AM   #560
Evilstealth's Avatar
Send a message via MSN to Evilstealth
Comon dude tell us how you do it
http://www.rctech.net/forum/electric-road/290595-new-offline-rollout-calculator.html#post5695222 - Offline Rollout Calculator
Evilstealth is offline   Reply With Quote
Old 11-10-2007, 12:26 PM   #561
Really those readings mean absolutely nothing.... there is only one place to proove a good motor - on the track.
i bet if you put a load on this motor it would be crap!!
Mike
ixlr8nz is offline   Reply With Quote
Old 11-10-2007, 04:58 PM   #562
Nice job I beleive you now. Oh are those Snap On or Craftsman pliers you use when you twist the armature. I can twist a johnson and get 29,000 rpm but its cheating and no one likes a cheater.
Old 11-11-2007, 03:29 AM   #563
I agree with u, no1 likes a cheater. But i am aready infamous in my country for tuning silver can, so whether i tweak or never tweak the motor ppl will not believe. Anyway the highest rpm and amp draw i got on my silver can is about 40000rpm and draw about 5amps, but it is not usable.
Anyway this motor have aready being proven on the track by alot of drivers.
Old 11-11-2007, 06:17 PM   #564
rccardr's Avatar
See pic below.
No cranko, no cheato, just hard work gained from 20 years of running these things.
Silver Can Motor Tips/Tricks-silver-can-7-point-2-volts-rpm.jpg
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 11-12-2007, 04:28 AM   #565
Default Run in
Hi,
2volts at 12 hrs? clockwise rotation break in?
ty..
joel
rccartips is offline   Reply With Quote
Old 11-12-2007, 06:56 AM   #566
tc3team's Avatar
Power going in is power going out, maybe they have better cells? Or charged them at a higher amperage? Just a thought for you to think over
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 11-12-2007, 11:12 AM   #567
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by rccardr View Post
See pic below.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-12-2007, 09:46 PM   #568
Swift and Sleek's Avatar
Default EI JO!
Originally Posted by rccartips View Post
Hi,
ty..
joel
JOEL IS THIS YOUR BREAK IN REGIMEN FOR MABUCHI?
"TEAM BAD BOYS"
FOR THE LOVE OF THE GAME
Swift and Sleek is offline   Reply With Quote
Old 11-16-2007, 09:48 AM   #569
Hi remember me I was usually on the front page.
Old 11-16-2007, 12:10 PM   #570
ChuckWick357's Avatar
Hey guys,
I am New to the forum, and greatly inexperienced in electric racing.
I just bought a Mini, I broke in the motor using the water method.
The thing is much faster in reverse then forward. Is there anything I can do to fix this?
I assume this has been covered; a good link would be appreciated
ChuckWick357 is offline   Reply With Quote
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 02:44 PM
Silver Can (Mabuchi) Motor Tricks miller1990 Electric On-Road 1 03-06-2007 10:06 PM
Co27 motor tuning tips, hints, or tricks schmidt452 Electric Off-Road 16 11-08-2006 11:04 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 10:54 AM
