Silver Can Motor Tips/Tricks
#466
Yes, that is exactly what I mean. The silver can snout is larger than a standard 540 brushed motor can, so enlarging the entry port will yield more precise readings.
#467
Location: SOCAL the fastest mini cooper guys in the nation
I just bought a johnson 540 j motor yesterday and I see that you are posting alot on this section. Can you help me please to make my motor go faster. I have tried dipping it in water for 2 hours and nothing happens. I also tried toothpaste and that didnt help. My last resort was kerosine but on my way back from the camping store to my house I caught my car on fire. Please help me I just want to be fast like all the other guys.
Thanks,
Your friend in need
#469
thanks mate, my dyno now works alot better! so whats an avg rpm reading on a silvercan these days!
#470
GIGANTIC TIP: Buy a dozen motors and break them all in. Statistically, one should be a genetic mutant (e.g. FASTER) motor. Repeat for each fast motor you want.
#471
Sir,
Thanks,
Your friend in need
Thanks,
Your friend in need
1. Water dip for a few minutes ... or use the trinity bushing buster to get the brushes fully seated. this can also be accomplished by using the motor for a few weeks.
2 Polish the comm and bushings with Brasso or Bright boy or any type of brass polish. I use a drill, chuck it to the motors shaft, (without the pinion), turn the motor with the drills power and drip yer polish directly on the comm and also a bit on the bushings. you can do this for 5 minutes or an hour.
3. clean our the motor with warm water and motor cleaner or simple green.
4. let it dry and dyno each one ... one of them should be good, if not, buy 3 more and repeat!!
I hope that helps, I know searching threads here is impossible
#472
Buy 3 motors and break them all in, not just one.
#473
It helps if you run the motor.
Gotta use the organic kind- Crest and Colgate don't do the trick.
Much better results- bet you drove a lot faster when you saw the flames!
#474
Very nice and so respectful of your elders. Come talk to me in 30 years about how fast you are.
No question that you are an excellent driver, but if you'd run my stuff you'd be studying Japanese right now...
#476
That there is a true statement I had alot of fun I just don't know how my car went from completley dialed to crap in a couple of hours all I did was change tires and still used the same inserts. Oh well I had fun how about you.
#477
I find it impossible to believe that anyone could attend a TCS event- Nats or Regional- and not have fun, no matter where they finish.
Couple of years ago I would podium seven or eight times in a season. Between getting older (which I am certain some would characterize as "washed up") and the amazing number of talented drivers now participating in the Series (like Mr. Koslosky), I seldom wind up in the top three more than a couple times each season.
On the other hand, I did win Seattle this year...
BTW, pic below is where we were this afternoon. Had a nice piece of caribou for dinner with a lovely Zin...
#478
#479
The rc-dc knows is stuff on silver can motors. I was lucky enough to run his motors at the Trackside TCS and they were much stronger than anything I was able to tune/run.
Doc., are you going to make it to the Mini-Madness race at Trackside. RC- gary, the Keys and others should be there. It would give you the chance to see WI without all the snoww. It's really a nice place.
Think about it.
Think about it.
#480
Yep, I will be there. Wouldn't miss it.
