Old 05-19-2007, 12:34 AM   #406
Send a message via AIM to A-Ko
hope it helps ya!
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 05-19-2007, 09:45 AM   #407
volracer's Avatar
Send a message via ICQ to volracer
Just duct tape them to ignition wires of your car on your way to the track.
"Lord forgive me, someone will reply they have tried this and it works." - Larry the Ignition Wire Guy.
Also, it had better not win in "Pit Tips".
volracer is offline   Reply With Quote
Old 05-20-2007, 10:54 PM   #408
acko's Avatar
is that to your spark plug leads. r ya takin the piss or wot
TEAM TRASH TALK TOURING
losi mini baja/ sidewinder brushless on 3s li-po
losi xxxt mf2/ speed passion brushless 4.5 + li-po
pti goliath crawler... (always being modified)
hpi baja 5b ss 29.5 cc setting up 4 1/4 scale speedway
acko is offline   Reply With Quote
Old 05-22-2007, 04:01 AM   #409
volracer's Avatar
Taping your motors to ignition wires is a joke. I have never heard that zapping silver can magnets work, actually, I have heard silver cans are fastest before they wear out which is when the magnets are weaker.
Old 05-22-2007, 07:01 AM   #410
acko's Avatar
i use the black musachi or wotever it is and i can assure you they arnt any quicked before they die. they just drop off
Old 05-22-2007, 07:21 AM   #411
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
Any comments about HPI silver can (Saturn 27T)?
Mike Schumacher is offline   Reply With Quote
Old 05-22-2007, 11:07 AM   #412
wog....supraman's Avatar
Send a message via MSN to wog....supraman
Originally Posted by AUSSIE BOB
Gday, opening the can is the easist thing to do, hold can in hand, with the brush end up and the shaft end down, drop hard against a peice of wood, presto, falls apart. Now the question is, get the bastard back together again, i was a scrutineer and I wanted to see if it could be done without being seen and leaving marks. I have tried on three motors and can not do it, i know someone can with a week to spare and you can come on here and say that, but for what it is worth, just get another motor and run it in. I caught a cheat many years ago in Canberra off road with a stock arm in a silver can and caught him out with little marks left behind, but that is another storey, .................eh Darryn
AUSSIE BOB, PS, looking for Frewers Web Site, cant find it
Originally Posted by MUAHDIB4
Ok, I figured I'd ask here since some discussions on other boards keep leaning towards major changes in the hobby to slow racers down rather than start a class based on silvercan motors. I keep getting told that it's real easy to open one, make changes, advance the timing and all that though nobody can show me how. I've read through this thread and the concensus seems to be that you can't open one without causing enough damage that if you could get it back together, it wouldn't pass a basic tech inspection...right? I've been racing them in my M03s for a while and never tried to open one and have no need to but I'd like to know if these people are right in saying that it's easy and everyone does it.
Originally Posted by RCCARDR
1) It is not possible to open a modern silver can motor and put it back together without it being very obvious. Period.
2) It is not possible to crank a modern silver can motor (advance the timing) without killing it due to the cam lock installed when it is manufactured. Period.
3) It is possible to advance the timing slightly on a modern silver can motor using a magnet zapper, but while RPM goes up, torque goes waaaaaay down.
I hate to go against someone with more experience than myself (one been in it for a year n a half)(my number of posts dont reflect my intelligence though...coz the i would have zero posts ) but, a couple weeks ago i roasted my motor at the 540 classics....and i had an old silvercan which had been rippd apart (long story)..so i cleand the comm and stuck the 23t sport tuned armature in the silvercan and sealed it back up.....noooo scratches what so ever...xcept the fact i used the sport tuned end bell and not the silvercan 1
I tested the motor out...just stuck it on my 4200 stik pak.....it squeals....real real loud.....does this mean it needs a clean....it also started melting the battery pack holder (4 cell) (i stuck 4 AA's in a pack n tried it again) and the plastic on the batt holder startd to melt....the bateries were hot....the motor must have been pulling alot of current.....scorching hot it was.......
1. What does the squealing mean???? time for a clean???
cheers
Tamiya TNX5.2R, Taniya TA05, Tamiya TB-02, Team Associated Factory Team B4, Twister CP V2, HoBao Pirate 10 MT, Tamiya TNX5.2R spare chassis x2, ebay spec submarine, HSP Rock crawler! FOR SALE!!! pm me
wog....supraman is offline   Reply With Quote
Old 05-22-2007, 11:17 AM   #413
Hustler's Avatar
cheers
...uh, Houston? We have a problem....
Hustler is offline   Reply With Quote
Old 05-22-2007, 11:21 AM   #414
I know that...hehehehehehehe
thats why i askd....my mate said to water dip it (sorta like break-in) then CRC it then lube her up
wat do you think people
Old 05-22-2007, 06:27 PM   #415
rccardr's Avatar
I think you need some ignition wires and duct tape.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 05-23-2007, 05:11 AM   #416
AUSSIE BOB's Avatar
Default V8
If you own the blue HO'e doing the burn out, ......get the 8 ignition wires together, ........tape them up so there is one piece about 6 inches long of wire and tape tight, ................place 540 motor on it and tape it up all together....................and shove it up your arse you cheat !!!!!!!!!!
AUSSIE BOB
AUSSIE BOB is offline   Reply With Quote
Old 05-23-2007, 05:47 AM   #417
tc3team's Avatar
I have always wanted to race a non compliant 540 but its a no brainer.
I worked out a special formula for it.
Racing + tampered with 540 - rac - tampered with 540 + cheat =
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 05-23-2007, 07:30 PM   #418
acko's Avatar
i agree wit you blokes with the cheat side of things but, i came on this thread looking for mabye a little trick or something that is good to have in your back pocket and may not nessasarly be illegal. putting a silver can innards in a black can is something i wouldnt waste my time with, but he has to do something more with car handling b4 he starts worring about car speed
LAPPING
Old 05-23-2007, 07:33 PM   #419
rccardr's Avatar
HEY NOW!!! EVERYBODY knows that will simply retard the timing and slow the motor down!!!
I've never lost.
Old 05-23-2007, 10:45 PM   #420
rough512's Avatar
SQUEALING = dry motor bushings.
rough512 is offline   Reply With Quote
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 02:44 PM
Silver Can (Mabuchi) Motor Tricks miller1990 Electric On-Road 1 03-06-2007 10:06 PM
Co27 motor tuning tips, hints, or tricks schmidt452 Electric Off-Road 16 11-08-2006 11:04 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 10:54 AM
