Old 04-18-2007, 07:33 PM   #391
rccardr's Avatar
I've seen it done, they all throw winds however
My point exactly. Attempting to crank a motor with a lock damages the winding.
I made the mistake of water dipping one of those motor and ruined it in a matter of minutes.
Put it in the car and drive it for five minutes, then clean. That'll do the trick. If water dipping, be veewwwwwwy cawwefuuuulll...30 seconds at a time. More fun to run it in the car, though...
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 04-18-2007, 08:19 PM   #392
xrayroooahhhh's Avatar
Default motor break in!!!
A friend of mine travels to Saudi Arabia on buisness a couple of times a month. On his days off....when he's there......he searches for a special root from a small indiginous shrub. Each root will give up a couple of drops of moisture........liquid gold as he calls it.......he swears that his silver can motors will produce incredible numbers when a tiny amount gets put on the comm during break in!!!!
-ROOH RACING-
www.donerite.net
xrayroooahhhh is offline   Reply With Quote
Old 04-19-2007, 07:09 AM   #393
Steven Key's Avatar
LOL Good One
My son made me promise never to tell but here goes. We rub seven Tibetan herbs and spices very slowly on the outside of our silver can motors to get that extra special something out of them. Their not really any faster but they do smell good.
Steven Key is offline   Reply With Quote
Old 04-19-2007, 07:52 AM   #394
dmatter's Avatar
Just Remove From Box and Bolt in Car! Watch how it gets Faster for the first few Runs Then after it starts to slow down, Spray it out with Motor Spray until the Run Off is Clear. First Lubricate the Bushing with Super Super Light Oil This will Get Lubricant "Into" The Bushing, Then Move Armature Back in Forth to "Work" in Lubricant, then Back it up with a good Heavier Bushing Lube and Work "into" the Bushing. After I lube a Bushing I leave the Motor In an Upright Position to get the Oil "Into" the Bushing Just for about a Minute, then I do the Other Side. The light oil Saturates the Bushing and the heavier oil is a better lubricant because it don't Burn off as easy.
Dax
dmatter is offline   Reply With Quote
Old 04-19-2007, 02:22 PM   #395
Default only 7?????
Originally Posted by Steven Key
LOL Good One
How do you expect KFC to sponsor you if your short 4 essentials!!!
-ROOH RACING-
www.donerite.net
Old 04-19-2007, 07:47 PM   #396
rough512's Avatar
As a last step in silver can tuning. Store you motors and batteries inside a pyramid. It helps preserve and even enhances the magnets.
It also breaks down the crystals forming in your battery.
NOTE: I read from an ancient book from way way back that the pyramid sides should form 35 degrees with the ground. This should be exactly followed
MORE PYRAMID POWER INFO HERE
rough512 is offline   Reply With Quote
Old 04-21-2007, 06:43 AM   #397
Send a message via AIM to A-Ko
Shake-N-Bake. . . would be good with a side of fries.
The cool thing about black canned motors is they look like real cars when they blow an engine. Gotta love that white smoke look!
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 05-13-2007, 10:16 PM   #398
mac853's Avatar
Arrow
I HAVE HEARD ABOUT THE TOOTHPASTE, YEAH?
HOW ABOUT TO USE IT IN SILVER MOTORS, WATER DIP?
COULD SOMEBODY EXPLAIN IT LITTLE BIT MORE?
AND I HEARD ALSO THERE SOME COMM DROP TO PUT IN SILVER MOTORS TO GETTING MORE RPM. COULD ANYBODY TELL ME WHICH ONE OF WHICH BRAND ARE BETTER AND MORE CONVENIENT? PLEASE
mac853 is offline   Reply With Quote
Old 05-14-2007, 12:51 AM   #399
acko's Avatar
can someone please explain motor zapping to me. how it is done, what are the benifits etc.... I ve heard the term b4 but it would be good to know. any fead back would be muchly appreciated
thankyou
TEAM TRASH TALK TOURING
losi mini baja/ sidewinder brushless on 3s li-po
losi xxxt mf2/ speed passion brushless 4.5 + li-po
pti goliath crawler... (always being modified)
hpi baja 5b ss 29.5 cc setting up 4 1/4 scale speedway
acko is offline   Reply With Quote
Old 05-14-2007, 01:58 PM   #400
Zapping is the term used when electronically "adding" more magnetic field to your motor. Thus with stronger magnets you can get more power, more torque and more gearing into the motor.
Think of your motor/magnets as a cup. Cups come in different sizes which is indicated as the materials used in the motors/magnets. You can fill up the cup but you will reach their limits when the liquid overflows. Same thing happens to magnets, they only fill so much.
Does it work, it can but usually it might effect older motors than newer ones. I tried it on 3 new hand-out motors for a race, did not really change anything. Is it worth the hassle, well if you are looking to beat factory drivers on an international scale, it "might" make a difference if you are looking for every little trick to gain an advantage.
Some motors might need zapping after every race while other might only need it once. Could Silver Canned motors benefit, perhaps but their magnets are not too good to begin with. I do not worry about it.
Jeffrey
Old 05-14-2007, 04:46 PM   #401
Dan the Man's Avatar
Trader Rating: 40 (100%+)
thankyou
Too late for the 540 Classic big boy! Looking at that zapper for sale are we?
*continues sneaking around the forums stalking acko*
|--|Hot Bodies Pro 5|-●-|The "F109X"|--|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 05-14-2007, 07:04 PM   #402
acko's Avatar
thankyou for yor repley a-ko dan ya funny bugger. i read about zapping but it doesnt tell ya how 2 do it. is there one for sale. never seen one. the only way i could think of doing it would be how you magnetize a screw driver by wrapping wire around it putting 1 end of the wire to neg of 12v battery and the other 2 pos side
Old 05-14-2007, 08:53 PM   #403
James's Avatar
hahaha
http://www.teamadrenaline.net/ - RC Race Results, News, and gossip in Australia!
http://www.nolimitarcade.com/ - the best web flash games
http://www.fireflyhelicopter.com/ - R/C heli vids 'n more
James is offline   Reply With Quote
Old 05-15-2007, 05:10 AM   #404
Yeah that is close but alot more wire. Usually the lights dim when you flip the switch. The cheaper ones start at around $500.
Jeffrey
Old 05-15-2007, 07:00 PM   #405
acko's Avatar
roger roger.thanks very much for your input there a-ko
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 02:44 PM
Silver Can (Mabuchi) Motor Tricks miller1990 Electric On-Road 1 03-06-2007 10:06 PM
Co27 motor tuning tips, hints, or tricks schmidt452 Electric Off-Road 16 11-08-2006 11:04 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 10:54 AM
