Old 02-03-2007, 04:31 AM   #331
hav_lova's Avatar
I'm a bit late on this topic guys, on the topic of fast 540's i've done all sorts of crazy things with them, most were destoryed in my enthusiasm to find some miracle way of making fast 540's. But i had one that would touch 16,000rpm at 5V!!!! and it was 100% legal, i'm all against cheating i would volunteer to scrutineer 540 just to discourage cheaters. Anyways the motor never hit the track glueing my tyres i split CA on the motor and glued the amature in one spot. I have had a 540 working up to 20,000 rpm then throw a winding, i won't say what voltage it was at but it wasnt the 7.2 usually required. I'm still stumped as to why it threw a winding....
Just playing with bigger toys now...
serpentrc.com.au
hav_lova is offline   Reply With Quote
Old 02-03-2007, 06:26 AM   #332
Default You finally got one?
Originally Posted by AUSSIE BOB
Finally got a four slot motor, cleaned it up and run it in etc etc, 26,400. Not bad but a wee bit over our 17,500 allowable rev limit
AUSSIE BOB
PS Professor, didnt run it last night but !!!!!!!! Barry nearly got me in his DNA
That's odd my dad used to work in a factory that used them for dust busters when I first raced and I've got a pile of them around here somewhere.
As for the kerosene trick, I used to clean out the motor after a race day by submerging the entire can in the stuff while it was running and then flushing it with (well I forgot the long winded name but it's called 'trike' or dry cleaning fluid)...worked a treat.
Mabuchi540 is offline   Reply With Quote
Old 02-03-2007, 08:49 PM   #333
AUSSIE BOB's Avatar
Default Mabuchi, NO NO NO NO NO
Do not use Trike, it is short for a bloody long name that is a chemical that is fatal even if it goes onto your skin a few times and it stays in your system, like lead, they banned it years ago in Australia, i think it is called Carbontecklochorid or similar, someone will know, but dont use that for $%#$% sake. The best is WD40 or motor cleaner, a lot safer.
BOB
AUSSIE BOB is offline   Reply With Quote
Old 02-04-2007, 01:34 AM   #334
Exclamation Wynn's Spitfire Brake and Parts Cleaner.....
BOB
(an Australian company btw) contains:
700g/kg of tetrachloroethylene in a 500g can.
"tetrachloroethylene" is dry cleaning fluid.
Perhaps the 'trike' part was wrong but that's what I've always called it.
Major edit: Trike = tri-chloroethylene
Dry cleaning fluid = tetra-chloroethylene
The tetra one still needs precautions (gloves) but I've never seen anything better for cleaning a comm on a 540!!!!
Old 02-04-2007, 02:26 AM   #335
AUSSIE BOB's Avatar
Default Gloves
Mate, if you need gloves to use it, count me out
AUSSIE BOB
Old 02-04-2007, 04:26 AM   #336
Post Well you don't have.....
AUSSIE BOB
to use gloves it's just that out of the can on your skin it can get incredible cold, probably freezing.
On a motor it can sometimes ice over, sort of like you get on a windscreen, just depends on what the day itself is like. But if it's a cold day the motor can get to cold to touch (hence the gloves).
Old 02-28-2007, 03:08 AM   #337
peejay's Avatar
Originally Posted by Mauri
what does the coke do?
It cleans stuff. Put an old penny in your glass of coke and see what happens
peejay is offline   Reply With Quote
Old 02-28-2007, 03:22 AM   #338
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
can i just put the silver can into a glass with water and direct it on a battery and spins it for about half a minute? will it help to clean the motor?
nikkiesteban is offline   Reply With Quote
Old 02-28-2007, 05:01 AM   #339
Default That can work.....
but having done that for many years back in the late 80's early 90's the thing I found most important is to listen for the pitch of the motor to change. Once it's in the water on a fully charged battery at some point in the first minute there will be a noticable change in the sound that it makes. As soon as the sound changes take the motor out and it should be screaming its head off. Leaving the motor in beyond the point that the noise changes is pointless. Also rather than water you can try kerosene, but no matter what you use once ou take the motor out flush it through with electrical contact cleaner.
Old 02-28-2007, 07:35 AM   #340
Teddygoat's Avatar
If you guys are looking for a fluid that can help clean a 540 motor, try adding Harpic toilet cleaner to your water, about a teaspoon to 250ml of water. Run your motor in this for a few minutes and you'll have a com that sparkles! It also safe!
Teddygoat is offline   Reply With Quote
Old 02-28-2007, 07:36 AM   #341
Teddygoat's Avatar
OH forgot to mention thats between 3 and 4v
Old 02-28-2007, 07:43 AM   #342
xrayroooahhhh's Avatar
Default Harpic????
Is this a acidic bowl cleaner or a milder enviro-friendly type????
-ROOH RACING-
www.donerite.net
xrayroooahhhh is offline   Reply With Quote
Old 02-28-2007, 07:48 AM   #343
Teddygoat's Avatar
Its active ingrediient is Benzalkonium chloride 0.32% m/m, so it slightly acidic, its also mountine pine sent, so my motor smells good all day!
Old 03-14-2007, 06:55 AM   #344
muahdib4's Avatar
Send a message via Yahoo to muahdib4
Ok, I figured I'd ask here since some discussions on other boards keep leaning towards major changes in the hobby to slow racers down rather than start a class based on silvercan motors. I keep getting told that it's real easy to open one, make changes, advance the timing and all that though nobody can show me how. I've read through this thread and the concensus seems to be that you can't open one without causing enough damage that if you could get it back together, it wouldn't pass a basic tech inspection...right? I've been racing them in my M03s for a while and never tried to open one and have no need to but I'd like to know if these people are right in saying that it's easy and everyone does it.
KCRC - Kansas City Remote Crawlers
Team Chucklenuts Racing
Midwest R/C Rally Confederation
KC/RC Drift Movement
muahdib4 is offline   Reply With Quote
Old 03-14-2007, 02:23 PM   #345
loopedeloop's Avatar
Apparently they are easy to open but very difficult to put back together without leaving signs that it has been opened.
Its easy to advance timing but also easy to check current draw on a motor checker.
Over here we are enforcing a 1.7A max current unloaded at 8 volts.
If your motor draws close to the limit it is subject to a 2nd test in reverse direction. If the current draw is different the tech person can disqualify you as this points to the motor being "timed".
Best just to leave it alone and run it in properly for the best performance.
You will spend the rest of your life trying to shake off the label "CHEATER"
It just aint worth it
loopedeloop is offline   Reply With Quote
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 02:44 PM
Silver Can (Mabuchi) Motor Tricks miller1990 Electric On-Road 1 03-06-2007 10:06 PM
Co27 motor tuning tips, hints, or tricks schmidt452 Electric Off-Road 16 11-08-2006 11:04 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 10:54 AM
