Old 10-03-2006, 09:31 AM   #196
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
You can first sort out the types of silver cans.. ones with 4 small vent holes are generally faster than the newer 2 large vent holes..
Also, ones with a different "endbell" (for a lack of a better word) colour and shape.. the newer johnsons have a dark blue endbell, one older one I have has a silver endbell (probably a mabuchi), and it goes like a demon.. faster than any other silver can I've known, more like a sport-tuned..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 10-03-2006, 07:08 PM   #197
PeteB's Avatar
A really cheap way of "feeling" the difference is to get a large-ish prop from an RC plane, and attach it to the motor, and apply some power to the motor ** CAREFULLY ** hold the motor the motor out in front of you, so that you wont lose a finger in the prop (seriously- be careful, I had a prop spin backwards (trailing edge is the sharp side) and it vertically split my finger and fingernail half an inch down from the tip of my finger... WEAR PROTECTIVE GOGGLES!
anyway, hold it out in front of you and you should be able to feel how much power the motor has by the amount of wind genereated, very technical I know
Pete
JRXS-R
GTB SS + 13.5 & 10.5
Trakpower 4900
Supernova
Nomadio
PeteB is offline   Reply With Quote
Old 10-03-2006, 08:49 PM   #198
coons88's Avatar
Send a message via MSN to coons88
A cheap way I use is to just run the motors off a charged battery and listen to the pitch of the sound it makes. Whichever one makes the highest pitch sound is generally the quickest. Then to test for torque, just the motor in your hand, but with a very loose grip on it. Then plug it into the battery and see how much the motor spins in your hand. Whichever motor moves the most has the most torque.
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 10-03-2006, 09:00 PM   #199
shift's Avatar
i made my own dyno. what i did was make a mount for the motor then ran a belt from that motor to another motor and it spun the other motor which creates voltage and i measure the voltage the other motor makes and and which ever has the highest voltage is the best. also i got a car speedo and hooked it up and i meseared a motor on a proper dyno at certain voltages then i was able to put numbers on and see what the rpm is. ill post a pic when i get my camera back
shift is offline   Reply With Quote
Old 10-03-2006, 09:36 PM   #200
PeteB's Avatar
Thats awesome, I have tried building a slave motor dyno, but couldnt really get any useful info out of it...
maybe I was measuring the out put incorrectly, I thought to measure power, using Ohms law, you multiply volts and amps. If I know the volts going into the test motor and then measure the amps being generated by the slave motor, you get power (less any losses) in the test motor. Is that right?
JRXS-R
Trakpower 4900
Supernova
Nomadio
Old 10-03-2006, 09:40 PM   #201
coons88's Avatar
Thats an awesome idea.
Old 10-03-2006, 09:53 PM   #202
AUSSIE BOB's Avatar
Default fast
Coons88, I did the "listen" thing, I thought my fastest was a motor, i did the "dyno" thing and then the "run in car" thing and it was number three, the motor that sounded the slowest was in fact the fastest in all forms. Just a sideline, the guy that said he had a 30,000 silver can still has not got back to me with a price
AUSSIE BOB is offline   Reply With Quote
Old 10-03-2006, 10:02 PM   #203
PeteB's Avatar
Yeah, Im not sure how accurate the free rev sound will be, thats why I like the prop, it is a constant load. if you could measure the rpm of the prop, that would give more accurate results.
JRXS-R
Trakpower 4900
Supernova
Nomadio
Old 10-03-2006, 11:18 PM   #204
DerekEngland's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to DerekEngland Send a message via Yahoo to DerekEngland
Make a mount and use a bicycle computer.... it will give you some indication.... just not a RPM.
Schumacher USA
R/C Paints by Sonny
DerekEngland is offline   Reply With Quote
Old 10-06-2006, 12:47 AM   #205
RocketRacer's Avatar
is 19000rpm on a a 540 motor good? what type of rpm are we aiming for with this motor? what should the amp draw be at 19k rpm???
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 10-06-2006, 12:49 AM   #206
shift's Avatar
what voltage are you running at
Old 10-06-2006, 12:57 AM   #207
7.2volts on a Team Integy Indi Dyno V2
RocketRacer
Old 10-06-2006, 12:59 AM   #208
shift's Avatar
yeah i would say that is good rpm. not to sure on amp draw
Old 10-06-2006, 01:02 AM   #209
thanks
RocketRacer
Old 10-06-2006, 02:40 AM   #210
hav_lova's Avatar
Try 5 volts and let me know, most of my motors are 13,000+ at 5 volts and i had one that did 13,600-13,800 @5v that was a missile on the straight. Most people say my motors aren't faster then theirs on a straight but i'm usually geared around 3 teeth lower then most.
Just playing with bigger toys now...
serpentrc.com.au
hav_lova is offline   Reply With Quote
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 02:44 PM
Silver Can (Mabuchi) Motor Tricks miller1990 Electric On-Road 1 03-06-2007 10:06 PM
Co27 motor tuning tips, hints, or tricks schmidt452 Electric Off-Road 16 11-08-2006 11:04 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 10:54 AM
