Old 06-10-2012, 09:34 PM   #1636
I can relate to excessive play being caused by F1 cars hitting things! Here in Japan I compete in the Tamiya Challenge Cup and we use the Formula Tuned motor. It is a common thing to see the end bells come off during a race. One guy in my club glued the end bell onto the can only to have the armature punch right through the end bell on his last time out! I will use a spacer on the pinion shaft from now on as mentioned by rccardr.
Check that maybe the excessive play isn't due to the end bell deforming due to the armature bashing it in crash.
Simonmadcap is offline   Reply With Quote
Old 06-18-2012, 08:35 PM   #1637
Kenny, this was the thread referred to
Granpa is offline   Reply With Quote
Old 07-12-2012, 11:59 PM   #1638
monkeyracing's Avatar
Wow. I'm finally deleting my subscription to this thread. My plan is to run through what I've got left and never run a silver can (in a race) again.
Vaya con dios, shiny little amigo.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 07-19-2012, 03:24 AM   #1639
Butler205's Avatar
Is there any value in breaking in a motor that's already been run for a season in a M03 without any real break in?
I was looking at rccardr's technique here:
http://www.rctech.net/forum/electric...g-break-3.html
I assume it doesn't matter if a motor has been run before or not. The goal of seating the brushes properly still applies.
M05 Racer(retired) FF03 Racer - Brushless Hyper 7 Basher
Butler205 is offline   Reply With Quote
Old 07-19-2012, 04:43 AM   #1640
sosidge's Avatar
If the motor has been run in a car for a year already it is probably going to be pretty well run in.
If you peer in through the side of the motor you should be able to see how much of the brush is in contact with the comm, as you probably know the brushes are curved perpendicular to the comm when new, after some running in they will make contact with the full width of the comm, and after even more running you will have the full face of the brush making contact. The motors are quite close to the end of their life by then, but that is also when they are at their quickest!
Old 07-19-2012, 09:55 AM   #1641
Most of your observations are correct, but when the full face of the brush comes into contact with the comm is when the motor is "broken in". Most motors can be run till there is almost no brush left. In fact some of these motors were fastest then.
Just a heads up for Silvercan fans. Apparently, a new Mabuchi motor is going into the kits. Do not know the part # or very much about it. A few examples were brought to the Tamiya track for testing or previewing. The motors were 10 to 20% faster revving than the Johnson. In a Mini, performance was similar to the Blackcan. At first glance, it looked like the SH and end bell and brushes looked like a Blackcan. Unfortunately, I only had the motors for a few minutes and was not one of those who were able to fit it to their own cars.
Old 07-19-2012, 03:46 PM   #1642
malcnz's Avatar
I wonder if its the torque one that I got a while ago and they say on the box its between a silver can and tuned in performance..it was cheaper than a silver can to buy $10usd at stella models and a different nicer silver can and end bell is certainly different..I never used it as we only allow silver cans with specific part numbers and I can take some pics if anyone wants to see it?
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 07-20-2012, 11:06 AM   #1643
rccardr's Avatar
Default New silver can from Mabuchi
Have heard of these but not yet seen one.
If they are faster revving than the standard Johnson by that much, Bob, makes a boy wonder if they are equipped with stock 27 turn armatures or something a little zippier (black cans are 23's).
If anyone has a NEW one that they'd like to give up for testing and (hopefully) performance improvement, give me a shout at [email protected].
Meanwhile, folks keep asking so we just keep bangin' out the Red Dots: TCS, 15K, F1, Full Race, you name it. Can't keep 'em in stock.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 07-20-2012, 02:11 PM   #1644
Tracy B's Avatar
I have several silver can j-johnson motors from Tamiya, is there a way to tell which side is + and which is -?? I can not find any markings on the motor itself.
TRex chassis with McAllister Xfinity Ford Mustang
Member of WRCRC
Authorized HobbyWing, Gens Ace batteries, McAllister Racing Bodies, and Precision Racing Systems dealer: [email protected]
www.facebook.com/BroeckerRacing
Tracy B is offline   Reply With Quote
Old 07-20-2012, 02:49 PM   #1645
On the can, you'll see that one side has some tabs stamped into the can. which are used to position the magnets. The other side is smooth with a tiny square hole near the end bell. The smooth side is positive and the stamped side is negative.
Also when you first receive the motor it came with yellow and green wires. Yellow wire is + and green is -.
Old 07-20-2012, 03:00 PM   #1646
Tracy B's Avatar
Mine are used motors that no longer have the wires on them, but thanks for the info on how to determine + and -.
Member of WRCRC
Old 07-20-2012, 03:07 PM   #1647
davenz's Avatar
Hey Malcnz. is this the motor you mentioned from stella models?http://www.stellamodels.com.hk/54358...or-p-6276.html
Sakura Zero - hw v3.1 sp13.5
3 racing cactus - 10.5 trackstar
davenz is offline   Reply With Quote
Old 07-20-2012, 03:13 PM   #1648
You're probably right, Doc. Best guess might be a Blackcan armature in a SH can. with 0 degrees advance. That would give the rpm #'s I saw on the motor tester. Overall impression was a cheap substitute, even tho it was a faster revving motor.
Old 07-20-2012, 04:09 PM   #1649
malcnz's Avatar
yeah thats it...nice finish on it than the std silver can and definatly a different end bell which is more removable.
Silver Can Motor Tips/Tricks-dscf1075.jpg   Silver Can Motor Tips/Tricks-dscf1076.jpg   Silver Can Motor Tips/Tricks-dscf1077.jpg   Silver Can Motor Tips/Tricks-dscf1083.jpg   Silver Can Motor Tips/Tricks-dscf1084.jpg
Old 07-20-2012, 05:20 PM   #1650
jsr555's Avatar
Trader Rating: 17 (100%+)
Some also have a small dot, molded into the end bell next to the soldering tab. This is the positive mark.
More removable... that sounds legal..
Xray T4 & HPI/HB Pro 5 - Powered by Hobbywing
SQ: HPI RS Pro -HPI RS Pro 2 - HPI Pro 3 - HPI Pro ?? - HPI Pro 5
jsr555 is offline   Reply With Quote
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 02:44 PM
Silver Can (Mabuchi) Motor Tricks miller1990 Electric On-Road 1 03-06-2007 10:06 PM
Co27 motor tuning tips, hints, or tricks schmidt452 Electric Off-Road 16 11-08-2006 11:04 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 10:54 AM
