Old 03-17-2011, 05:09 AM   #1501
rccardr's Avatar
If you must water dip, use a slave motor to drive the new motor (run the slave backwards to drive the new motor in the correct direction). DO NOT lube or use comm drops on the new motor before water dipping. Run it at 4 volts (should pull about 5-6 amps) for 2 minutes and check- it should be pretty close. Only run it until the brushes are JUST straight up and down.
Then lube and use comm drops (we like VooDoo drops) and run at 7.2 volts for 6 to 8 minutes (directly, not with a slave motor). It should be somewhere around 13-13,500RPM @ 5 volts, or 19K + @ 7.2 volts.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 03-17-2011, 11:15 AM   #1502
Are there any drawbacks or advantages to breaking in a motor at a lower voltage other than the extra time it takes?
Stregone is offline   Reply With Quote
Old 03-17-2011, 12:24 PM   #1503
IndyHobbies.com's Avatar
Is there a "normal" operating temp for silver cans? What is the redline temp?
We are running them in a "Bomber" class in Indy. I've got mine in a TC3 with an FDR of 6.0 (max allowed). Gangstar Body from Parma.
Silver Can Motor Tips/Tricks-cadzilla-003r.jpg
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
Member Hoosier RC Racers club - www.HRCRacers.com
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 03-17-2011, 06:56 PM   #1504
rccardr's Avatar
180F is danger zone
160F is ideal but will kill the motor after 5-6 runs
140F is pretty good and the motor will live longer
120F is undergeared
I've never lost.
Old 03-17-2011, 08:18 PM   #1505
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Deaths-a-Bitch View Post
Has any one got a good way of running in these newer CS brushes,
I have been water dipping for age's but it would be lucky if its bed in 2mm of the tip of the brush. I have not been using any comm drops just lubing the bushes.
I know what you mean... i actually wore one of these motors out and the brushes looked the same as the first day I tried to water dip it.... it was weird. Nothing I did seemed to work... higher amps and all...
Fishhook
ewashburnaf is offline   Reply With Quote
Old 03-17-2011, 08:21 PM   #1506
Originally Posted by [[john]] View Post
Hi Guys!
My Red-Dot (Full Race) motor got knocked back by the scrutineers today - Their main concern besides the strength of the magnets was the 'CS' stamped onto the brushes - Is this normal in the Tamiya 540j's ?
One on-looker suggested the motor had been bought un-assembled, worked and then sealed to look like a standard 540j.
I'm more curious then disappointed as I still TQ'd with a standard silver-can from a Tamiya kit.
TIA!
That sucks man... they need to get with the times... almost all the newer 540-J's are CS stamped
Fishhook
Old 03-18-2011, 03:00 AM   #1507
PizzaDude's Avatar
Originally Posted by rccardr View Post
180F is danger zone
120F is undergeared
Measured at the can, com, or...?
Thanks mate
PizzaDude is offline   Reply With Quote
Old 03-18-2011, 05:05 AM   #1508
rccardr's Avatar
Measured through the vent, at the comm. That's the hottest part of the motor. You can try through the endbell vents if the can vent holes are blocked, but it will be somewhat lower.
I've never lost.
Old 03-18-2011, 05:53 AM   #1509
PizzaDude's Avatar
I also measure at the comm.
In the case of mabuchi/Johnsons like you through the lare vent holes in the can.
Old 04-12-2011, 09:04 AM   #1510
Misiek's Avatar
Can you use sewing machine oil to lube the silver can motor?
________________________________________________________
On paternity leave...
Misiek is offline   Reply With Quote
Old 04-12-2011, 07:26 PM   #1511
j.d.roost's Avatar
Trader Rating: 28 (100%+)
3n1?
I have used it but it tends to get gooey and pick up alot of track crap.
If you want an off the shelf oil,get some light weight Mobil 1.
A qt. will last a lifetime.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 04-13-2011, 11:33 AM   #1512
Misiek's Avatar
Originally Posted by j.d.roost View Post
3n1?
"Sewing Machine Oil"
I might try Mobil 1 (any specific kind you would recommend?)
Old 04-13-2011, 01:47 PM   #1513
theatriks's Avatar
Does anyone know of a website that explains what part is what on a silver can motor ?
theatriks is offline   Reply With Quote
Old 04-13-2011, 03:00 PM   #1514
j.d.roost's Avatar
I have used 5w20.
F1
Roche usa
R.I.P. Jon Williams
Old 04-14-2011, 04:54 AM   #1515
rccardr's Avatar
Do a search on this thread and you'll find the results of testing we did in the Lab about various motor oils and why Mobil 1 5wt was the superior performer.
There used to be a page on the Mabuchi or Johnson web site showing an exploded view of a 540 motor. Not sure it's still up there, but worth the search.
I've never lost.
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 02:44 PM
Silver Can (Mabuchi) Motor Tricks miller1990 Electric On-Road 1 03-06-2007 10:06 PM
Co27 motor tuning tips, hints, or tricks schmidt452 Electric Off-Road 16 11-08-2006 11:04 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 10:54 AM
