Body ground clearance >
Like Tree7Likes
Old 04-26-2019, 03:33 AM
  #16
Originally Posted by WagwanBumba View Post
Per title!
How much ground clearance do you normally give your touring car body? I've not really been considering this in setting up cars/body pairs in a consistent manner and can't really find much information on the discussion of this topic.
Saw a video by Alexander Hagberg of Xray, if I recall around 8mm front lip and 11mm side.
rccartips is offline
Old 04-26-2019, 04:01 AM
  #17
LzREngineering's Avatar
Don't forget it's important for the body to have a bit of up-travel. This means that if the shell does touch the ground momentarily you don't get any significant weight transfer away from the tyres and through the shell, which can be a cause of the car snapping out mid-corner.
WagwanBumba likes this.
LzREngineering is offline
Old 05-08-2019, 02:18 AM
  #18
It really depends, if you're on a parking lot with no grip, you can do flat with the chassis. if your car actually rolls and you have 5-5.5mm ride height, the universal answer is a normal sized sharpie around the entire thing. the more complicated answer for my medium grip asphalt home track, 7mm side, 8mm front splitter with the car race ready. i typically run my front posts a hole loose and allow the splitter of a type-s to hit the asphalt on occasion in the sweepers.
Brian Bosley is offline
