CRC CK25 Asphalt >
CRC CK25 Asphalt
Like Tree1Likes
  • 1 Post By BullFrog
CRC CK25 Asphalt
Old 04-20-2019, 11:56 AM
Trader Rating: 21 (100%+)
Default CRC CK25 Asphalt
I have searched the forums and looked through setup websites, but can't seem to find what I am looking for.
I would like to run a CK25 on a resurfaced and painted tennis court. I am planning to use a 21.5 or 17.5 to keep tire wear down and would like to stick with spec tires to keep cost down. Does anyone have any ideas for a good starting setup? I haven't run pan cars before and want to use this as a way to get more laps in without making the 2 hour drive to the track. I also have a timing system to keep myself honest and improving with setups.
Thank you!
-Chris
chjosi is offline
Old 04-21-2019, 09:51 AM
I run black carpet but ran several times on the surface you are going to run on. I raised the ride height a little and out of the box crc specs with the 21.5 GT12. Also did noy want to scratch the bottom of the chassis. Put some clear contact paper on . A roll lasts a long time.
chjosi likes this.
BullFrog is offline
