Old 03-02-2006, 01:04 AM   #1
BugFreak's Avatar
Default Charging..
Hi!
When I charge my cells (3300's), they keep cutting on temp, instead of peak.. I charge at 4.5 to 5amp. Is this normal?
(the charger reads 3400 and 3500mah when done..)
Svein E. Pedersen
- tamiya4ever -
BugFreak is offline   Reply With Quote
Old 03-02-2006, 01:16 AM   #2
Hi,
The charge amps looks fine,I've charged my 3300s with that range for practice.
By the way,are your cells old? Old cells with higher internal resistence could be a reason why it peaked due to temp.
But everthing looks normal to me.
Ben.C is offline   Reply With Quote
Old 03-02-2006, 01:32 AM   #3
lookinco's Avatar
What temp do they cut off at? Maybe your temp setting is too low, or your peak setting is too high.
lookinco is offline   Reply With Quote
Old 03-02-2006, 03:30 AM   #4
BugFreak's Avatar
I have a new charger, the Overloader, and I tried to use the same cut-off as my old Robitronic Expert, and it cut waaaaay early, so now I have the cut of at 10 to 11, instead of 4 and 5 that worked for the Expert. The cells are brand new team packs.. Temp-cut is at 45deg C. (113 Fahrenheit)
Svein E. Pedersen
- tamiya4ever -
Old 03-02-2006, 04:11 AM   #5
lookinco's Avatar
I believe you could set your temperature cut-off to be a little bit higher. Somewhere around 120F ~ 130F. My 3300 usually cut off at delta peak with the temp around 120F ~ 126F and 3500mah.
charging hillbillyrcer Micro and Mini Scales 9 01-16-2008 03:58 AM
Charging ? NitroMaxx3.3 Nitro On-Road 7 06-18-2007 02:57 PM
need help with charging please mikezilla Australian Racing 9 04-11-2006 05:17 AM
Charging. How to? Mossie Australian Racing 14 01-27-2004 02:32 PM
