Like Tree447Likes
Tamiya M-08
Old 03-31-2024, 08:02 AM
  #931
GerryH's Avatar
Trader Rating: 26 (100%+)
Which swaybar are you using? The blue one does have a habit of binding if you crank the swaybar holder screws (philips ones, not hex) down too much. Just disconnect the ends and tighten each philips screw until it doesn't move freely then back it off.
GerryH is offline
Old 03-31-2024, 02:49 PM
  #932
Samich's Avatar
Finally got the bug body painted. Its actually on an M05 since I didn't want to convert my M08 to the short wheelbase. The eyes are just sharpie marker until I can get some stick on googly eyes.
Looking forward to raceday!
Dan, Herc Driver, Raman and 6 others like this.
Samich is offline
Old 04-01-2024, 07:10 AM
  #933
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Haha, love it!!
Dan is offline
Old 04-02-2024, 08:30 PM
  #934
Schs2013's Avatar
I am using the red one with the hex hardware from since the M08R came with the hex hardware.
Schs2013 is offline
Old 04-06-2024, 08:26 AM
  #935
Would love to see some video of this
Revolter22 likes this.
leadfootedfool is offline
Old 04-09-2024, 08:54 AM
  #936
For those that like something different like the Renault 5 Turbo but dislike the way the wheels hide in the body because the body is so wide at the rear.
I installed:
53500
54610
54969
9804700
all Tamiya parts but now my rear is almost 180mm wide and fills up the body well.
Will test it out on next run. Currently my M07 and M08 are running similar times. A bit faster with the M08 but more consistent with M07 with a bit of luck this gives me a more solid rear, and if not the Renault 5 turbo just looks fun nd different.
Zanquis is offline
Old 04-09-2024, 08:58 AM
  #937
Hardly worth it, but I'm a sucker for blue.
Aluminum Frame Posts (54966)
The biggest benefit and reason why I got these was that it was easier/safer to quickly change wheelbase as I was less likely to ruin the threat with the Blue alu than the plastic kit stuff.
Zanquis is offline
Old 04-12-2024, 01:52 PM
  #938
Ready for the race, love the short wide look of it.
Zanquis is offline
Old 04-12-2024, 04:17 PM
  #939
Schs2013's Avatar
Sticker Time track body. Concourse body to be done soon.
Schs2013 is offline
Old 04-25-2024, 06:31 PM
  #940
Herc Driver's Avatar
Ok…I have a 07. Just got a second hand (but new) 08.
question?
is the consensus alum Front 0 degree “bulkhead” and 07 C hubs and spindles?
is this all that’s needed?
thanks
track is smooth asphalt if that matters
Herc Driver is offline
Old 04-25-2024, 06:35 PM
  #941
Built MWB….agan if this matters
Old 04-26-2024, 08:36 AM
  #942
Raman's Avatar
Trader Rating: 94 (100%+)
question?
thanks
Correct.
Raman is offline
Old 04-26-2024, 08:45 AM
  #943
I appreciate your help….is the alum part specific to the 08 or same one as the 07?
thanks again as always
gonna order today
Old 04-26-2024, 10:51 AM
  #944
Dan
Dan's Avatar
Spindles are the same. The M07 C hub is 0 degree. You will need a 4, 5 or 6 degree caster plate.
All the M08 or M07 caster plates are interchangeable between platforms.
ruebiracer likes this.
Dan is offline
Old 04-26-2024, 11:17 AM
  #945
Thank you….is there a better plate to start with? 4/5/6
