Like Tree443Likes
Tamiya M-08
Old 11-27-2023, 04:34 PM
  #871
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
We will meet again! It was cool how we just all happened to meet under just the right circumstances.
Just need to infiltrate Tamiya and find out the source of the blue carpet.
Dan is offline
Old 12-16-2023, 03:33 PM
  #872
The Big Wig's Avatar
Default 📸🏆
Originally Posted by rccartips
M08s dominated the Tamiya World Championship here in Japan. The best qualifying M07 was only 9th on the grid. Lotus Europa and MX5.
Any pics of the winning cars?
EB Racer likes this.
The Big Wig is offline
Old 12-16-2023, 09:03 PM
  #873
Originally Posted by Raman
When we decided to run Mini, I chose the 06 over my 08, due to the rear motor. I also had a lot more wheel time with 06 on asphalt versus the 08. The 3Racing speed gears also give it ability to have a lower FDR, to match the gearing flexibility of the Sakura MG / Xpress. So far it seems to be the right choice. Down the road, we will have to limit FDR to keep the 07/08 competitive.
Raman,
Check out part number O-AP0001 on RC Mart. Its a high speed gear set that fits the M07. I assume it works with the M08 which shares the same spur and counter gear. The only difference the M08 having the idler. The other benefit is the spur is 48 pitch, so you can ditch the .6 mod.
This gets the gearing very low, on my M07R the highest FDR you can achieve is 3.6. We run open 21.5t, my first run with this gear set i almost ended up in the timing table after overshooting the turn after the straight. The only downside is heat, especially during the summer here in San Diego with a track temp of 110+ deg. I dont even want to know what the track temp is out by you guys lol.
I've been following the 702 club since things kicked back off. Next time i visit my parents, ill bring a few cars and hope it lines up with a race. Looks like you guys are really picking up momentum.
Raman and CARD like this.
Techno Duck is offline
Old 12-17-2023, 08:22 AM
  #874
Raman's Avatar
Trader Rating: 94 (100%+)
Originally Posted by Techno Duck
Raman,
😉 Arrived yesterday!!! Will test out on both M06 and M08 and report back.
CARD, ruebiracer and jo_er86 like this.
Raman is offline
Old 12-17-2023, 03:21 PM
  #875
No pics. All I could see was the winning car pitched and rolled more than the others, soft suspension. Europa body (no wing).
By the rules, the M08 had a low profile/cg body advantage (Europa, Ghia, MX5) while M07 were limited to using hatchbacks (Yaris, Swift, Mazda2).
Attached Thumbnails Tamiya M-08-371239028_7260159757356853_6812669181325517429_n.png
ruebiracer likes this.
rccartips is offline
Old 12-18-2023, 08:17 PM
  #876
Raman's Avatar
Another words, if the 1:1 was a rwd then it has to be on an M08 and if the 1:1 is a fwd, M07. TCS in US used to have this rule but it was relaxed.
Rules to be respected by those who drive manly 💪 cars 😉
Raman is offline
Old 12-19-2023, 04:41 AM
  #877
DirkW's Avatar
No rule for that here either, unfortunately. Seeing a VW Bug or an Alfa Romeo Giulia Sprint GTA on an FWD chassis during last weekend's M-Chassis race here, actually kinda hurt. I could never do that. But that race was open, not limited to Tamiya so there were also race truck bodies and in the 4WD class (!), some people even ran pure TC style bodies. While 2WD raced cheap hand-out brushed motors, 4WD raced 17.5T blinky. Needless to say, 4WD class simply looked more like a (albeit smaller scale) TC race than M-Chassis. Luckily that (abomination of a ) class only got half as many starters as 2WD did.
Anyway, I had loads of fun with my M-08R. I had my M-07R with me as an option as well (different body, of course! ), but decided to stick with the RWD on that carpet, even though I could not really get my setup straightened out enough to really feel happy with the car (it either pushed through corners - or it traction rolled. Never got it quite right...). But in general there's just something about M-Chassis racing... it's great fun.
Raman and ruebiracer like this.
DirkW is offline
Old 12-19-2023, 10:46 AM
  #878
Raman's Avatar
After many years we got M-Chassis off the ground and I didnít want to make it too strict to turn people away.. so at present there are plenty look alike M chassis bodies and one TC style. Iím sporting my Alpine 110.. and itís does really well.
Raman is offline
Old 01-04-2024, 07:45 AM
  #879
Can the #54787 aluminum rear arm mounts be used to change roll center?
Friulimotosport is offline
Old 01-04-2024, 11:12 AM
  #880
Dan
Dan's Avatar
Yes, I have these also but haven't gotten enough time to play around and test with it.
Dan is offline
Old 01-04-2024, 01:52 PM
  #881
Dan
Dan's Avatar
My sweet new body for the M08.
Dan is offline
Old 01-04-2024, 07:26 PM
  #882
Looks Awesome Dan
Dan likes this.
Team Wenz is offline
Old 01-04-2024, 07:33 PM
  #883
I've got a M-08, new in box that I'd sell for $175 shipped if anyone is interested.
CTRJ is offline
Old 01-05-2024, 06:18 AM
  #884
Samich's Avatar
After a several year hiatus, I've picked up an M08r now that I have a track nearby. IIRC, the last time I raced (2016 TCS) I was using the 1016 pre-mounted radials. Along with the kit I picked up a set of 54999, a set of 54995, and the 54590 inner foams.
I haven't had to glue tires in a long time, but I just can't get the foams to sit nicely without the tire being lumpy nor can I get the tire bead to sit flush against the rim.
Should I be trimming the foam at all?
Samich is offline
Old 01-05-2024, 06:32 AM
  #885
That shell actually goes ok lol! Someone entered it for the concourse at a round of the Tamiya Iconic Cup here in the UK last year and as per the rules they had to then use the shell for at least one qualifier. You can see it around 30 seconds here and at 2:17. Not sure if there is any footage of it going. Oh yes skip to about 11:35 https://www.youtube.com/watch?v=_OvHFjQU6Io&t=612s
dlruk is offline
