Like Tree347Likes
Tamiya M-08
Old 03-29-2023, 02:58 PM
  #781
Raman's Avatar
Trader Rating: 89 (100%+)
Originally Posted by rccartips
M04 ready for Tamiya Cup when I came across a cheap M08. Hopefully faster ​​​​​​
I love the M08.. fantastic chassis.
Raman is offline
Old 03-29-2023, 03:01 PM
  #782
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
question :you love over the M07??
OVA is offline
Old 03-29-2023, 04:12 PM
  #783
Raman's Avatar
answer: never owned an M07 😉
FWD gives me a rash
Dan, OVA, rccartips and 2 others like this.
Raman is offline
Old 04-01-2023, 06:18 AM
  #784
Are the carbon reinforced suspension arms hubs etc good or better to stick with the stock plastic? Thanks
rccartips is offline
Old 04-01-2023, 06:25 AM
  #785
_
Old 04-02-2023, 07:22 PM
  #786
Plastic parts tend to not explode on impact, which means you'll get to finish the race. Carbon is great for top drivers that don't crash much...
bertrandsv87 is offline
Old 04-03-2023, 08:09 AM
  #787
Raman's Avatar
Ive used the plastic since having the car. Never switched to the carbon. You're usually on asphalt, so probably better to stick with plastic
Raman is offline
Old 04-03-2023, 03:59 PM
  #788
hotdognobun's Avatar
Trader Rating: 32 (100%+)
Default servo
Is there suppose to be a gap between the servo and chassis? I am using a Protek lo-pro 160SS
hotdognobun is offline
Old 04-03-2023, 04:52 PM
  #789
Raman's Avatar
Mine sits flush. Maybe the wire is slightly ticked lifting it?
Raman is offline
Old 04-03-2023, 05:29 PM
  #790
Are you using the same servo?
Old 04-03-2023, 06:34 PM
  #791
First time out the M08 managed to be as fast in a single lap as my M04 with Tamiya 15.5T brushless motors (lots of power). Easy to drive and less prone to traction rolling.
Sadly I will retire my M04 after 20 years.
Raman likes this.
Old 04-03-2023, 06:38 PM
  #792
Raman's Avatar
No, I use Futaba low profile servos
Raman is offline
Old 04-04-2023, 02:27 AM
  #793
DirkW's Avatar
Yes, IIRC you need a low profile servo. not a "standard" size for the M-08 car to fit properly. The M-07 also normally uses low profile, but has some plastic adapter pieces come with the kit to fit "standard" size servos as well. Parts A6 and A7 - looks like they are included with the M-08 as well, but probably are not supposed to be used with the whole steering geometry being different.
(Somehow it starts to feel a bit weird to call it "standard" size, when low profile de facto has become the new standard size in most racing oriented chassis )
DirkW is offline
Old 04-04-2023, 07:10 PM
  #794
hotdog, I have a Protek lo profile 140T on order. I should get it in Thursday. Hopefully it will fit flush to the mount. I'll let you know.
Rinskie is offline
Old 04-05-2023, 12:05 AM
  #795
Default Servo
Yeah I went to my local hobby shop and can tell you not all low profile are created equal. Unfortunately every model they had was also tall. I have an MKS X6 on order because the measurement shows its more compact and identical in measurement to Tamiya’s low profile servo that is shown on M08r demo
