Like Tree389Likes
Tamiya M-08
Old 03-03-2023, 12:08 PM
  #751
Scionara05's Avatar
Originally Posted by Dan
Shimming the steering rack helps. Honestly the aluminum option part has more slop than the stock plastic pieces funny enough...
I've read. Been lurking for a while after winning my 08r at tcs(well my son did in the raffle) in Jackson and with outdoor season getting ready to kick off I figured get it up to snuff. Still have parts to order like the m07 front caster bits for durability. How are the aluminum c hubs or stick to plastic?
Scionara05 is offline
Old 03-03-2023, 12:36 PM
  #752
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Stick with the Tamiya M07 front C-hubs (make sure to get the matching caster plate). Even the carbon version M07 C-hub is relatively still durable. I would not run the M08 C-hubs with the stupid insert.
For the rear hub, the aluminum option piece is pricey but allows more adjustment options. On my M08R, I'm still running the plastic rear hub and feel it is already in a good roll center position.
Dan is offline
Old 03-03-2023, 01:31 PM
  #753
Scionara05's Avatar
will gluing them in help with durability. Also has anybody tried the m05 or m06 aluminum c hubs if they fit or is that not allowed also?
Old 03-03-2023, 02:43 PM
  #754
Dan
Dan's Avatar
Ok, ignore my advice, lol
Dan is offline
Old 03-03-2023, 03:34 PM
  #755
Scionara05's Avatar
just spit balling here lol. Can't know if it works if I don't ask. ​​​​​​​
Dan likes this.
Old 03-03-2023, 04:26 PM
  #756
Trader Rating: 20 (100%+)
Significantly less steering slop (even over a full aluminum steering rack/shimmed setup).
However, it is not legal for TCS, I have confirmed with Fred.
Thank you. We do not have TCS. Sounds like a good solution.
zleader_99 is offline
Old 03-03-2023, 05:57 PM
  #757
Raman's Avatar
Trader Rating: 91 (100%+)
Yep, this is correct. The hop up steering has the worst tolerance I have seen in a Tamiya hop up. Don’t waste you money and stick with the plastic
ruebiracer likes this.
Raman is offline
Old 03-03-2023, 10:27 PM
  #758
Schs2013's Avatar
Originally Posted by sosidge
The extra black/blue ones are. But the standard gold springs are not from a set.
Thanks for that i was finding them a little softer than the blue from the spring set which is why i asked. the gold springs i will try them at some point. but have to start racing more. always asphalt season i suppose to get more practice.
Schs2013 is offline
Old 03-04-2023, 06:23 AM
  #759
ruebiracer's Avatar
And 1 deg toe out also helps stopping wandering. And a shimmed plastic steering setup with the open face ball adjusters has very little slop. No problem at all for running straight.
Scionara05 likes this.
ruebiracer is offline
Old 03-05-2023, 10:39 AM
  #760
I've been out of RC for a good long while now and decided to pick up a M08 to mess around with on the tennis courts at my apartment. The plan is to take my time and relearn how to drive and tune a car and maybe race down the road. I also picked up a Sanwa MT-R, a Tamiya FL Tuned 30T and a Tamiya 04 speed control. Not looking for anything super quick, just running around type stuff. I know I should consider the M07 rear uprights but is there anything else I should know to make a solid sport beater? No clue on bodies or tires yet but I kinda like the Alpine or the Alpha. Thanks guys!
Rinskie is offline
Old 03-05-2023, 11:28 AM
  #761
Scionara05's Avatar
Body just came in. Mazda mx5, now to figure out the color for it. Anybody have any ideas I've always done spray bombs of ps18 purple on all my bodies for the past 5 years. So confused on witch way to go with it. I did a box art gt86 body for last year's tcs race that won best gt but that was just a copy past of what's on the box. The box art is so simple with this one lol
Old 03-05-2023, 02:52 PM
  #762
zuqbu's Avatar
In my opinion as soon as you hit a surface with any amount of decent grip you will want the 54757 sway bar set. If you have access to setup tools a cheap but very effective hop-up is the 54987 suspension mount shim set as the plastic parts as well as the kit shims can have tolerances and you might not have equal left/right rear toe and camber.
Rinskie likes this.
zuqbu is offline
Old 03-09-2023, 08:41 AM
  #763
xpressracer's Avatar
So I'm getting my M0-8r ready for TCS, racing on Black carpet, when I take off from the start line it instantly pulls to the left, using the gear diff with 15K in it, new hard radial tires, glued sidewalls and first row of tread. Any thoughts?
xpressracer is online now
Old 03-09-2023, 10:00 AM
  #764
sosidge's Avatar
Not unusual. Standing start will magnify any unevenness in traction. Feed the power in.
Raman likes this.
sosidge is offline
Old 03-09-2023, 11:06 AM
  #765
Raman's Avatar
On go everyone is trigger happy. With RWD, squeeze the throttle to get going.
Raman is offline
