Like Tree347Likes
Tamiya M-08
Old 02-28-2023, 05:08 AM
  #736
ruebiracer's Avatar
I also updated my setup sheet slightly. Maybe helpful for some of you. Car was really stable and consistent to drive again. But I definetely need a test day to fine tune and get it even a bit more aggressive, when staying at LWB.
ruebiracer is offline
Old 02-28-2023, 07:11 PM
  #737
Scionara05's Avatar
With outdoor season upon us what is a good baseline for an 08r. I know I know get the 07 but I already have this so I'm going to use it and have fun with it for now. I have s grip radials already and mediums also from my m05. Mazda mx5 body and pretty much kit setup with direct steering mod because it had way to much play in the steering. Track will be jackson rc in nj where the aug tcs will be. Tia
ruebiracer likes this.
Scionara05 is offline
Old 03-01-2023, 09:32 AM
  #738
ruebiracer's Avatar
If you look some pages back, Jesse Anderson did a lot of testing for a decent setup for Tarmac outdoor with his MX5. I think it was called Covid setup, Lol. I guess this would bea very good starting point to make some fine adjustments to your personal driving style / track conditions. Tirewise you maybe should think of the rules of your upcoming TCS event, in case you want to run there. IŽd try to use the tires used in the event as early as possible. S Grips are still a very good allround tire, but probably not continued by Tamiya. The replacements are the new Radials soft and hard type. They are very good. Even the hard type is alevel up from Grip vs. the old S-Grips, with a tad more wear. The hard ones are also good in the wet. A friend of mine run his new bone stock M06 with these tires in the rear with good success. (They come in the std. M06 kits in the rear from factory in the meantime).
Hope I could give you some hints, wish you fun for the upcoming outdoor season,
Matthias
Raman likes this.
Old 03-02-2023, 06:49 PM
  #739
Scionara05's Avatar
Originally Posted by ruebiracer
If you look some pages back, Jesse Anderson did a lot of testing for a decent setup for Tarmac outdoor with his MX5. I think it was called Covid setup, Lol. I guess this would bea very good starting point to make some fine adjustments to your personal driving style / track conditions. Tirewise you maybe should think of the rules of your upcoming TCS event, in case you want to run there. IŽd try to use the tires used in the event as early as possible. S Grips are still a very good allround tire, but probably not continued by Tamiya. The replacements are the new Radials soft and hard type. They are very good. Even the hard type is alevel up from Grip vs. the old S-Grips, with a tad more wear. The hard ones are also good in the wet. A friend of mine run his new bone stock M06 with these tires in the rear with good success. (They come in the std. M06 kits in the rear from factory in the meantime).Hope I could give you some hints, wish you fun for the upcoming outdoor season,Matthias
Any idea of what post number it is
Old 03-02-2023, 07:29 PM
  #740
Schs2013's Avatar
So are the stock kit springs black/blue the same as 53333 spring set? Hard blue spring?
Schs2013 is offline
Old 03-03-2023, 12:29 AM
  #741
sosidge's Avatar
The extra black/blue ones are. But the standard gold springs are not from a set.
sosidge is offline
Old 03-03-2023, 03:42 AM
  #742
ruebiracer's Avatar
Post 445!
Scionara05 likes this.
Old 03-03-2023, 06:39 AM
  #743
Trader Rating: 20 (100%+)
Good morning
Whats the advantage of the direct steering mod? I plan to drive on black carpet only.
zleader_99 is offline
Old 03-03-2023, 08:08 AM
  #744
Scionara05's Avatar
So I've ran the car in front of the house on the street and it seems to wonder left to right. Front toe is at 0 ATM rear I have 1mm on the rear hinge pin holder for toe in. Direct steering mod done because the steering never wanted to center correctly. Rear grip is good with the mustard color springs rear and s grip 60d and front blk/blue dot front with hard 60d front worn down to a ghost pin thread. Any i sea on the straight tracking all my other cars from xray and sakura don't suffer that issue?
Old 03-03-2023, 08:53 AM
  #745
sosidge's Avatar
If your plan is to race it I wouldn't spend too much time trying to rectify problems on the street, a track is very different.
Mine was a bit wandery at first. Mostly it is low grip from the rear axle. I think the 4/5/6 degree arm mount from the M-07 helps as well (more caster which helps stability)
sosidge is offline
Old 03-03-2023, 08:58 AM
  #746
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Originally Posted by zleader_99
Good morning
Significantly less steering slop (even over a full aluminum steering rack/shimmed setup).
However, it is not legal for TCS, I have confirmed with Fred.
Core Creations likes this.
Dan is offline
Old 03-03-2023, 09:22 AM
  #747
Scionara05's Avatar
even if it is a tamiya horn saver?
Old 03-03-2023, 10:59 AM
  #748
Dan
Dan's Avatar
Correct
Dan is offline
Old 03-03-2023, 11:00 AM
  #749
Scionara05's Avatar
Correct
well now that sux. Now how is a good way of getting s9me of the slop out the plastic bits for now
Old 03-03-2023, 11:05 AM
  #750
Dan
Dan's Avatar
Shimming the steering rack helps. Honestly the aluminum option part has more slop than the stock plastic pieces funny enough...
Dan is offline
