Tamiya M-08
#511
New tires that are legal for the TCS M-Chassis class
Tamiya 60D Radial Tires (soft) #54995
Tamiya 60D Radial Tires (hard) #54999
#512
#513
But great race results, keen on the setup details and the tires??
#514
I think I posted my setup somewhere on this thread in the past. I didn't deviate a whole lot from it. Honestly didn't have too much testing time but the rear end was a lot more locked in and didn't have the weird "loose halfway into the race" thing that the Ride tires did.
#516
And what tires exactly did you run instead of the RIdes? New rides have also bigger diameter than Tamiya Radials, so can have an disadvantage regarding topspeed in my eyes. But depends on the track layout for sure...
#517
#519
Think 10k but honestly forgot, haven't messed with the car much since 2019...
ruebiracer, the tires kwkride posted..
#520
I maybe said it not that clear, I referred to Dan not using the Rides, so guessed he could be a little slower in topspeed compared to the guys using the Rides. Officially, thes are also 60 D but more of a low profile tire. But they are also more of a balloon shape compared to the rather flat Tamiya Radial shapes. So with a set of new Rides, you tend to have a little bigger diameter. They settle in and after some batteries they get flatter, too. So what I wanted to say was, that on a big open track, the Topspeed can be a little higher using a set of new Rides from our experience.
#521
The Tamiya tires were about the same diameter as the Rides, maybe a tad taller actually. Diameter was similar.
#522
Seems I have to try the new versions now for comparison. I only can speak of the M- and S-Grips up to now...
#523
Any advice for stopping an M-08 from spinning out when accelerating?
I’m driving on a surface that might be atypical: very smooth concrete.
I’ve tried:
- hard tire inserts in the back, which helped a lot, but it still isn’t where I want it to be
- much thicker diff oil (12k) than seems to be the typical recommendation which helped a lot less than I thought it would and made the steering a lot worse. I tried this because I don’t have 5k around and 12k worked really well in the front diff of an XV-01 and a TT02 in similar conditions
I have a 2800kv motor in it currently.
I’ve tried:
#524
reduce your esc “punch” level to smooth out the power curve.
How’s your tire prep? Are you using a traction additive?
I’ve tried:
I’ve tried:
#525
I should maybe have asked this first: are m-class cars competitive with 4WD drive RC cars like XV-01, TT-02 or even Ta-02s?
